주요 콘텐츠로 건너뛰기
Asus Chromebook C300M Key Replacement
필요한 것
  1. Asus Chromebook C300M Key Replacement, Bottom Panel: 1 단계, 이미지 1/1
    • Flip the Chromebook over, bottom-side up.
  2. Asus Chromebook C300M Key Replacement: 2 단계, 이미지 1/2 Asus Chromebook C300M Key Replacement: 2 단계, 이미지 2/2
    • Remove the screws from the 11 spots using the aluminum driver with the J00 Philips head provided in iFixit toolkit.
    • Remove the eight 9.0mm Philips screws along the perimeter of the case.
    • Remove the three 6.0mm Philips screws from the center of the case.
    • Some versions may instead have six bigger screws (the four on the upper side of the image, close to the hinge, and two on the sides) and five smaller ones (four at the bottom of the image, where the laptop is thinner, and one in the center).
  3. Asus Chromebook C300M Key Replacement: 3 단계, 이미지 1/1
    • Using a plastic opening tool, work around the Chromebook separating the plastic case at the seam.
  4. Asus Chromebook C300M Key Replacement: 4 단계, 이미지 1/1
    • Open the Chromebook at hinges.
  5. Asus Chromebook C300M Key Replacement, Key: 5 단계, 이미지 1/1
    • Detach the wide black keyboard cable from the switchboard.
  6. Asus Chromebook C300M Key Replacement: 6 단계, 이미지 1/1
    • Unplug the white keyboard cable from switchboard.
  7. Asus Chromebook C300M Key Replacement: 7 단계, 이미지 1/1
    • Remove the keyboard from the laptop body.
  8. Asus Chromebook C300M Key Replacement: 8 단계, 이미지 1/1
    • Use the plastic opening tool to loosen a key of choice.
  9. Asus Chromebook C300M Key Replacement: 9 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Removed the loosened key with the tweezers.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Jake Van Loon
회원 가입일: 09/25/15
995 평판
안내서 3개 작성하였습니다
University of Tampa, Team 1-1, Whiteside Fall 2015 University of Tampa, Team 1-1, Whiteside Fall 2015 회원
UT-WHITESIDE-F15S1G1
3 회원들
안내서 8개 작성하였습니다
댓글 한 개
hello, i have a asus c300 my problem is when i open it i have get it just right to see picture .is it my video cable?
clint murchison - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 5,132
