주요 콘텐츠로 건너뛰기
Asus Chromebook C300M Mousepad Replacement
필요한 것
  1. Asus Chromebook C300M Mousepad Replacement, Mousepad: 1 단계, 이미지 1/2 Asus Chromebook C300M Mousepad Replacement, Mousepad: 1 단계, 이미지 2/2
    • Flip the Chromebook on its front.
    • Remove the screws on the back using the Phillips #1 screwdriver.
    • Remove the six 8mm screws.
    • Remove the five 5mm screws.
  2. Asus Chromebook C300M Mousepad Replacement: 2 단계, 이미지 1/1
    • Separate the plastic case from the keyboard at the seam by using a plastic opening tool.
  3. Asus Chromebook C300M Mousepad Replacement: 3 단계, 이미지 1/3 Asus Chromebook C300M Mousepad Replacement: 3 단계, 이미지 2/3 Asus Chromebook C300M Mousepad Replacement: 3 단계, 이미지 3/3
    • The small and wide ribbon cables connect the keyboard to the motherboard.
    • Disconnect the small ribbon cable by lifting the flap and sliding it out of the motherboard input toward the battery using a spudger.
    • Disconnect the wide ribbon cable by lifting the flap and sliding it out of the motherboard input toward the battery using spudger.
  4. Asus Chromebook C300M Mousepad Replacement: 4 단계, 이미지 1/3 Asus Chromebook C300M Mousepad Replacement: 4 단계, 이미지 2/3 Asus Chromebook C300M Mousepad Replacement: 4 단계, 이미지 3/3
    • Remove the keyboard and flip it onto its front. You should see the back of the mousepad.
    • Lift the foil strips to reveal two hidden screws. Then remove all four 2mm screws from the top of the trackpad with the Phillips #1 screwdriver.
    • Remove the mousepad by sliding it upward.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Rachel Cadle
회원 가입일: 04/02/19
259 평판
안내서 2개 작성하였습니다
IUPUI, Team S3-G2, Harley Spring 2019 IUPUI, Team S3-G2, Harley Spring 2019 회원
IUPUI-HARLEY-S19S3G2
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 340
