주요 콘텐츠로 건너뛰기
Asus Chromebook C300M USB Port Replacement
필요한 것
  1. Asus Chromebook C300M USB Port Replacement, USB Port: 1 단계, 이미지 1/2 Asus Chromebook C300M USB Port Replacement, USB Port: 1 단계, 이미지 2/2
    • Flip the chromebook on its front.
    • Remove the screws on the back using the Phillips #1 screwdriver.
    • Remove the six 8mm screws.
    • Remove the five 5mm screws.
  2. Asus Chromebook C300M USB Port Replacement: 2 단계, 이미지 1/1
    • Separate the plastic case from the keyboard at the seam using a plastic opening tool.
  3. Asus Chromebook C300M USB Port Replacement: 3 단계, 이미지 1/2 Asus Chromebook C300M USB Port Replacement: 3 단계, 이미지 2/2
    • Fully separate the plastic case from the keyboard by lifting it upward.
  4. Asus Chromebook C300M USB Port Replacement: 4 단계, 이미지 1/2 Asus Chromebook C300M USB Port Replacement: 4 단계, 이미지 2/2
    • The small and wide ribbon cables connect the keyboard to the motherboard.
    • Disconnect the small ribbon cable by lifting the flap and sliding it out of the motherboard input toward the battery using a spudger.
    • Disconnect the wide ribbon cable by lifting the flap and sliding it out of the motherboard input toward the battery using a spudger.
  5. Asus Chromebook C300M USB Port Replacement: 5 단계, 이미지 1/2 Asus Chromebook C300M USB Port Replacement: 5 단계, 이미지 2/2
    • Disconnect the USB port in the top right corner from the motherboard.
    • Unplug the the wide ribbon cable using spudger.
  6. Asus Chromebook C300M USB Port Replacement: 6 단계, 이미지 1/2 Asus Chromebook C300M USB Port Replacement: 6 단계, 이미지 2/2
    • Remove the single 3mm screw on the left and bottom side of the USB Port using the Phillips #1 screwdriver.
    • Remove the three 5mm screws on the upper part of the USB port with the same screwdriver.
    • Lift the edge of the white casing. Remove the USB Port by pulling it toward the bottom of the laptop.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Rachel Cadle
회원 가입일: 04/02/19
259 평판
안내서 2개 작성하였습니다
IUPUI, Team S3-G2, Harley Spring 2019 IUPUI, Team S3-G2, Harley Spring 2019 회원
IUPUI-HARLEY-S19S3G2
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 9
전체 시간: 763
