주요 콘텐츠로 건너뛰기
Asus Chromebook C300MA DB01 Battery Replacement
필요한 것
  1. Asus Chromebook C300MA DB01 Battery Replacement, Removing the Back Cover: 1 단계, 이미지 1/1
    • Remove the eight 9.0 mm Phillips screws along the perimeter of the case.
    • Remove the three 6.0 mm Phillips screws from the center of the case.
  2. Asus Chromebook C300MA DB01 Battery Replacement, Taking off the Keyboard: 2 단계, 이미지 1/2 Asus Chromebook C300MA DB01 Battery Replacement, Taking off the Keyboard: 2 단계, 이미지 2/2
    • Slide the Jimmy in between the keyboard and underside of the laptop to remove the keyboard.
    • Leave the keyboard face down on the screen.
    • Do not pull the keyboard away from the laptop. The keyboard will still be attached with wires.
  3. Asus Chromebook C300MA DB01 Battery Replacement, Detaching keyboard: 3 단계, 이미지 1/2 Asus Chromebook C300MA DB01 Battery Replacement, Detaching keyboard: 3 단계, 이미지 2/2
    • Use a nylon spudger to lift the latch on each wire jack and detach the keyboard wires.
    • After the tabs have been lifted, the wire can be gently pulled out by hand.
    • Set the keyboard aside.
  4. Asus Chromebook C300MA DB01 Battery Replacement, Removing the battery: 4 단계, 이미지 1/3 Asus Chromebook C300MA DB01 Battery Replacement, Removing the battery: 4 단계, 이미지 2/3 Asus Chromebook C300MA DB01 Battery Replacement, Removing the battery: 4 단계, 이미지 3/3
    • Remove the six 6.0mm Phillips screws on the battery.
    • Remove the wire jack from the battery. Use a nylon spudger to lift the latch.
    • Remove the battery from the device.
결론
Earl Gill IV
회원 가입일: 04/01/19
193 평판
안내서 2개 작성하였습니다
IUPUI, Team S10-G10, Wilson Spring 2019 IUPUI, Team S10-G10, Wilson Spring 2019 회원
IUPUI-WILSON-S19S10G10
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 10
전체 시간: 196
