주요 콘텐츠로 건너뛰기
Asus Chromebook C300MA DB01 Screen Replacement
필요한 것
  1. Asus Chromebook C300MA DB01 Screen Replacement, Screen: 1 단계, 이미지 1/3 Asus Chromebook C300MA DB01 Screen Replacement, Screen: 1 단계, 이미지 2/3 Asus Chromebook C300MA DB01 Screen Replacement, Screen: 1 단계, 이미지 3/3
    • Use a Jimmy to pry off the hinge cover from the screen.
  2. Asus Chromebook C300MA DB01 Screen Replacement: 2 단계, 이미지 1/2 Asus Chromebook C300MA DB01 Screen Replacement: 2 단계, 이미지 2/2
    • Run the Jimmy along the edges of the screen frame to unsnap it from the connectors.
    • Remove the screen frame manually.
  3. Asus Chromebook C300MA DB01 Screen Replacement: 3 단계, 이미지 1/3 Asus Chromebook C300MA DB01 Screen Replacement: 3 단계, 이미지 2/3 Asus Chromebook C300MA DB01 Screen Replacement: 3 단계, 이미지 3/3
    • Use a Phillips #1 screwdriver to remove the four screws on each corner of the screen.
    • Separate the screen from the top of the Chromebook with the Jimmy.
    • Avoid pulling the screen too far from the device as this can disconnect the wire located at the bottom of the screen.
    • Use the Jimmy to lift the latch on the wire jack.
    • Remove the wires and detach the screen from the device manually.
결론
Earl Gill IV
회원 가입일: 04/01/19
193 평판
안내서 2개 작성하였습니다
IUPUI, Team S10-G10, Wilson Spring 2019 IUPUI, Team S10-G10, Wilson Spring 2019 회원
IUPUI-WILSON-S19S10G10
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 5
30일 전: 7
전체 시간: 124
