주요 콘텐츠로 건너뛰기
Asus Chromebook C300MA-BBCLN12 Display Replacement
필요한 것
  1. Asus Chromebook C300MA-BBCLN12 Display Replacement, Display: 1 단계, 이미지 1/3 Asus Chromebook C300MA-BBCLN12 Display Replacement, Display: 1 단계, 이미지 2/3 Asus Chromebook C300MA-BBCLN12 Display Replacement, Display: 1 단계, 이미지 3/3
    • Wedge the tip of the plastic spudger between the outer display casing and the inner display panel liner.
    • Separate the outer display casing from the inner display panel by sliding the plastic spudger around the perimeter of the display.
    • It is necessary to pull the inner display panel firmly when separating it from the outer display casing along the bottom of the device.
  2. Asus Chromebook C300MA-BBCLN12 Display Replacement: 2 단계, 이미지 1/3 Asus Chromebook C300MA-BBCLN12 Display Replacement: 2 단계, 이미지 2/3 Asus Chromebook C300MA-BBCLN12 Display Replacement: 2 단계, 이미지 3/3
    • Remove the four 3.0mm PH00 screws from the four corners of the display.
    • Grip the edges of the display and tip it forward until it rests on the keyboard.
    • A cable connects the display to the display casing at the bottom. Separate the display panel slowly to prevent damaging the cable.
  3. Asus Chromebook C300MA-BBCLN12 Display Replacement: 3 단계, 이미지 1/3 Asus Chromebook C300MA-BBCLN12 Display Replacement: 3 단계, 이미지 2/3 Asus Chromebook C300MA-BBCLN12 Display Replacement: 3 단계, 이미지 3/3
    • Locate the gold cable connector that attaches the display to the bottom of the display housing.
    • Peel back the protective tape that covers the gold connector.
    • Disconnect the display from the display housing by gripping the sides of the gold display cable connector and pulling away from the bottom of the display.
결론
Brooke Austin
회원 가입일: 10/05/17
419 평판
안내서 4개 작성하였습니다
Portland State University, Team S1-G2, Read Fall 2017 Portland State University, Team S1-G2, Read Fall 2017 회원
PSUN-READ-F17S1G2
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 5
전체 시간: 215
