주요 콘텐츠로 건너뛰기
Asus Chromebook C300MA-DB01 Keyboard Replacement
필요한 것
  1. Asus Chromebook C300MA-DB01 Keyboard Replacement, Back Cover: 1 단계, 이미지 1/1
    • Place device bottom-side up.
  2. Asus Chromebook C300MA-DB01 Keyboard Replacement: 2 단계, 이미지 1/1
    • Remove the three 6.0 mm Philips screws from the center of the case with the #2 screwdriver bit.
    • Remove the eight 9.0 mm Philips screws along the perimeter of the case with the #2 screwdriver bit.
  3. Asus Chromebook C300MA-DB01 Keyboard Replacement: 3 단계, 이미지 1/1
    • Using a plastic opening tool, separate the bottom case at the seam.
    • Prying open a laptop requires a lot of force but use caution so as to avoid breaking the fragile connectors.
  4. Asus Chromebook C300MA-DB01 Keyboard Replacement: 4 단계, 이미지 1/2 Asus Chromebook C300MA-DB01 Keyboard Replacement: 4 단계, 이미지 2/2
    • Lift the keyboard panel away from the components at its hinges, which are located at the back of the laptop.
  5. Asus Chromebook C300MA-DB01 Keyboard Replacement, Keyboard: 5 단계, 이미지 1/1
    • Use plastic opening tool to pry open clip holding keyboard wires to the circuitboard.
  6. Asus Chromebook C300MA-DB01 Keyboard Replacement: 6 단계, 이미지 1/1
    • Use plastic opening tool to pry open clip holding mouse pad wires to the circuit board.
    • Use plastic opening tool to pry open clip holding keyboard flat black wire
    • Use plastic opening tool to pry open clip holding keyboard thiner white wire
  7. Asus Chromebook C300MA-DB01 Keyboard Replacement: 7 단계, 이미지 1/1
    • Lift and remove keyboard from device.
결론
wyatt boyatt
회원 가입일: 09/25/17
541 평판
안내서 5개 작성하였습니다
USF Tampa, Team S4-G3, Eyestone Fall 2017 USF Tampa, Team S4-G3, Eyestone Fall 2017 회원
USFT-EYESTONE-F17S4G3
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 10
전체 시간: 305
