주요 콘텐츠로 건너뛰기
Asus Chromebook C300MA-DB01 Screen Replacement
필요한 것
  1. Asus Chromebook C300MA-DB01 Screen Replacement, Screen: 1 단계, 이미지 1/2 Asus Chromebook C300MA-DB01 Screen Replacement, Screen: 1 단계, 이미지 2/2
    • Use plastic opening tool to remove the frame around the screen. It is recommended to start in the upper corners.
  2. Asus Chromebook C300MA-DB01 Screen Replacement: 2 단계, 이미지 1/2 Asus Chromebook C300MA-DB01 Screen Replacement: 2 단계, 이미지 2/2
    • Use plastic opening tool to remove plastic hinge casing located between the screen and keyboard.
  3. Asus Chromebook C300MA-DB01 Screen Replacement: 3 단계, 이미지 1/1
    • Use 64 bitdriver to remove 4 6.0 mm Phillips screws from screen the screws that need to be removed are located in the corners of the screen.
  4. Asus Chromebook C300MA-DB01 Screen Replacement: 4 단계, 이미지 1/1
    • Use plastic prying tool to detach the wire that connects the screen to the lower non-display half of the laptop.
  5. Asus Chromebook C300MA-DB01 Screen Replacement: 5 단계, 이미지 1/1
    • Lift and remove screen from the laptop.
결론
wyatt boyatt
회원 가입일: 09/25/17
541 평판
안내서 5개 작성하였습니다
USF Tampa, Team S4-G3, Eyestone Fall 2017 USF Tampa, Team S4-G3, Eyestone Fall 2017 회원
USFT-EYESTONE-F17S4G3
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 12
전체 시간: 342
