소개
The motherboard is the most important part of your devise. It is responsible of everything ranging from basic processing to complex programs.
필요한 것
Flip the Chromebook over so that the underside is facing up.
Using the Phillips PH #000 screwdriver, remove the 11 "4mm" screws on the back of the device.
Remove the 4 "4mm" screws on the silver motherboard cover with the Phillips #000 Screwdriver.
Remove the motherboard silver mount.
다른 2명이 해당 안내서를 완성하였습니다.
