주요 콘텐츠로 건너뛰기
Asus Chromebook C300MA-DH02 Motherboard Replacement
필요한 것
  1. Asus Chromebook C300MA-DH02 Motherboard Replacement, Keyboard Panel: 1 단계, 이미지 1/3 Asus Chromebook C300MA-DH02 Motherboard Replacement, Keyboard Panel: 1 단계, 이미지 2/3 Asus Chromebook C300MA-DH02 Motherboard Replacement, Keyboard Panel: 1 단계, 이미지 3/3
    • Flip the Chromebook over so that the underside is facing up.
    • Using the Phillips PH #000 screwdriver, remove the 11 "4mm" screws on the back of the device.
  2. Asus Chromebook C300MA-DH02 Motherboard Replacement: 2 단계, 이미지 1/1
    • Wedge the plastic opening tool between the bottom cover of the laptop and the keyboard panel.
    • Apply pressure and move the plastic opening tool around the border of the laptop until it pops out.
  3. Asus Chromebook C300MA-DH02 Motherboard Replacement: 3 단계, 이미지 1/2 Asus Chromebook C300MA-DH02 Motherboard Replacement: 3 단계, 이미지 2/2
    • Once the keyboard panel pops out, slowly move it upwards so that the keyboard connection is visible.
    • Remove the keyboard connection from the motherboard by pulling it outwards from the connector.
  4. Asus Chromebook C300MA-DH02 Motherboard Replacement, Motherboard: 4 단계, 이미지 1/2 Asus Chromebook C300MA-DH02 Motherboard Replacement, Motherboard: 4 단계, 이미지 2/2
    • Remove the 4 "4mm" screws on the silver motherboard cover with the Phillips #000 Screwdriver.
    • Remove the motherboard silver mount.
  5. Asus Chromebook C300MA-DH02 Motherboard Replacement: 5 단계, 이미지 1/1
    • Use a plastic opening tool to remove the connection from sound driver on the bottom left of the motherboard.
  6. Asus Chromebook C300MA-DH02 Motherboard Replacement: 6 단계, 이미지 1/1
    • Gently remove the blue connector to the right side of the motherboard.
  7. Asus Chromebook C300MA-DH02 Motherboard Replacement: 7 단계, 이미지 1/2 Asus Chromebook C300MA-DH02 Motherboard Replacement: 7 단계, 이미지 2/2
    • Use the Phillips #000 Screwdriver to remove the screw on right side of wireless card.
    • Remove the wireless card.
  8. Asus Chromebook C300MA-DH02 Motherboard Replacement: 8 단계, 이미지 1/1
    • Start by lifting tape up off of the connection. Remove the connection to display.
  9. Asus Chromebook C300MA-DH02 Motherboard Replacement: 9 단계, 이미지 1/3 Asus Chromebook C300MA-DH02 Motherboard Replacement: 9 단계, 이미지 2/3 Asus Chromebook C300MA-DH02 Motherboard Replacement: 9 단계, 이미지 3/3
    • Remove (3) three "4mm" screws that connect the hinge to the motherboard using the Phillips #000 Screwdriver.
    • Remove (5) five "4mm" screws around two sides of motherboard using the Phillips #000 Screwdriver.
  10. Asus Chromebook C300MA-DH02 Motherboard Replacement: 10 단계, 이미지 1/1
    • Gently remove motherboard from the Asus Chromebook.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Giang Le Nam Dang
회원 가입일: 10/02/17
149 평판
안내서 1개 작성함
USF Tampa, Team S6-G4, Remmell Fall 2017 USF Tampa, Team S6-G4, Remmell Fall 2017 회원
USFT-REMMELL-F17S6G4
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 9
전체 시간: 253
