주요 콘텐츠로 건너뛰기
Asus Chromebook C300MA-EDU Battery Replacement
필요한 것
  1. Asus Chromebook C300MA-EDU Battery Replacement, Keyboard: 1 단계, 이미지 2개 중 1개 Asus Chromebook C300MA-EDU Battery Replacement, Keyboard: 1 단계, 이미지 2개 중 2개
    • Flip the Chromebook onto its back, where there are eleven screws.
    • There are two variations of screws on the back panel:
    • Six 8.7mm screws.
    • Five 6.4mm screws.
    • Using your screwdriver with the J00 Phillips Head tip, remove the screws by turning them counter clockwise.
  2. Asus Chromebook C300MA-EDU Battery Replacement: 2 단계, 이미지 2개 중 1개 Asus Chromebook C300MA-EDU Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Once the screws are removed, flip the Chromebook back over.
    • Gently remove the keyboard by starting to lift up on one corner with a plastic opening tool.
    • Follow around the brim of the keyboard until it pops off.
  3. Asus Chromebook C300MA-EDU Battery Replacement: 3 단계, 이미지 3개 중 1개 Asus Chromebook C300MA-EDU Battery Replacement: 3 단계, 이미지 3개 중 2개 Asus Chromebook C300MA-EDU Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Once you remove the keyboard, it will be connected to the CPU with two tabbed connections.
    • Release the connections from the tabs gently by flipping the white flaps up until disconnected.
    • You can now pull the ribbons out from the board and remove the keyboard.
  4. Asus Chromebook C300MA-EDU Battery Replacement, Battery: 4 단계, 이미지 3개 중 1개 Asus Chromebook C300MA-EDU Battery Replacement, Battery: 4 단계, 이미지 3개 중 2개 Asus Chromebook C300MA-EDU Battery Replacement, Battery: 4 단계, 이미지 3개 중 3개
    • Once the keyboard is removed, the battery is located on the bottom portion of the shell.
    • The battery is held in with six 6.5mm screws on opposing sides.
  5. Asus Chromebook C300MA-EDU Battery Replacement: 5 단계, 이미지 2개 중 1개 Asus Chromebook C300MA-EDU Battery Replacement: 5 단계, 이미지 2개 중 2개
    • The battery is now held in with a tabbed connection to the CPU on the left side of the board. On the tabbed connection, there is a silver plate.
    • Gently push on the silver plate towards the screen until the plastic connection is free.
    • The tabbed connection should now slide out backwards.
  6. Asus Chromebook C300MA-EDU Battery Replacement: 6 단계, 이미지 2개 중 1개 Asus Chromebook C300MA-EDU Battery Replacement: 6 단계, 이미지 2개 중 2개
    • At this point, using the plastic removal tool, lift the battery out of the shell.
결론
작성자
3다른 기여자 명과 함께
Christopher Hart
회원 가입일: 09/28/17
501 평판
안내서 5개를 작성함
USF Tampa, Team S2-G3, Nance Fall 2017 USF Tampa, Team S2-G3, Nance Fall 2017 회원
USFT-NANCE-F17S2G3
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 12
전체 시간: 565
