주요 콘텐츠로 건너뛰기
Asus Chromebook C300MA-EDU Keyboard Replacement
필요한 것
  1. Asus Chromebook C300MA-EDU Keyboard Replacement, Keyboard: 1 단계, 이미지 1/2 Asus Chromebook C300MA-EDU Keyboard Replacement, Keyboard: 1 단계, 이미지 2/2
    • Flip the Chromebook onto its back, where there are eleven screws.
    • There are two variations of screws on the back panel:
    • Six 8.7mm screws.
    • Five 6.4mm screws.
    • Using your screwdriver with the J00 Phillips Head tip, remove the screws by turning them counter clockwise.
  2. Asus Chromebook C300MA-EDU Keyboard Replacement: 2 단계, 이미지 1/2 Asus Chromebook C300MA-EDU Keyboard Replacement: 2 단계, 이미지 2/2
    • Once the screws are removed, flip the Chromebook back over.
    • Gently remove the keyboard by starting to lift up on one corner with a plastic opening tool.
    • Follow around the brim of the keyboard until it pops off.
  3. Asus Chromebook C300MA-EDU Keyboard Replacement: 3 단계, 이미지 1/3 Asus Chromebook C300MA-EDU Keyboard Replacement: 3 단계, 이미지 2/3 Asus Chromebook C300MA-EDU Keyboard Replacement: 3 단계, 이미지 3/3
    • Once you remove the keyboard, it will be connected to the CPU with two tabbed connections.
    • Release the connections from the tabs gently by flipping the white flaps up until disconnected.
    • You can now pull the ribbons out from the board and remove the keyboard.
결론
Christopher Hart
회원 가입일: 09/28/17
501 평판
안내서 5개 작성하였습니다
USF Tampa, Team S2-G3, Nance Fall 2017 USF Tampa, Team S2-G3, Nance Fall 2017 회원
USFT-NANCE-F17S2G3
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 690
