주요 콘텐츠로 건너뛰기
Asus Chromebook C300MA-EDU Keyboard Replacement
필요한 것
  1. Asus Chromebook C300MA-EDU Keyboard Replacement, Keyboard: 1 단계, 이미지 2개 중 1개 Asus Chromebook C300MA-EDU Keyboard Replacement, Keyboard: 1 단계, 이미지 2개 중 2개
    • Flip the Chromebook onto its back, where there are eleven screws.
    • There are two variations of screws on the back panel:
    • Six 8.7mm screws.
    • Five 6.4mm screws.
    • Using your screwdriver with the J00 Phillips Head tip, remove the screws by turning them counter clockwise.
  2. Asus Chromebook C300MA-EDU Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Asus Chromebook C300MA-EDU Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Once the screws are removed, flip the Chromebook back over.
    • Gently remove the keyboard by starting to lift up on one corner with a plastic opening tool.
    • Follow around the brim of the keyboard until it pops off.
  3. Asus Chromebook C300MA-EDU Keyboard Replacement: 3 단계, 이미지 3개 중 1개 Asus Chromebook C300MA-EDU Keyboard Replacement: 3 단계, 이미지 3개 중 2개 Asus Chromebook C300MA-EDU Keyboard Replacement: 3 단계, 이미지 3개 중 3개
    • Once you remove the keyboard, it will be connected to the CPU with two tabbed connections.
    • Release the connections from the tabs gently by flipping the white flaps up until disconnected.
    • You can now pull the ribbons out from the board and remove the keyboard.
결론
작성자
3다른 기여자 명과 함께
Christopher Hart
회원 가입일: 09/28/17
501 평판
안내서 5개를 작성함
USF Tampa, Team S2-G3, Nance Fall 2017 USF Tampa, Team S2-G3, Nance Fall 2017 회원
USFT-NANCE-F17S2G3
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 9
전체 시간: 821
