주요 콘텐츠로 건너뛰기
Asus Chromebook C300MA-EDU LAN Card Replacement
필요한 것
  1. Asus Chromebook C300MA-EDU LAN Card Replacement, Keyboard: 1 단계, 이미지 1/2 Asus Chromebook C300MA-EDU LAN Card Replacement, Keyboard: 1 단계, 이미지 2/2
    • Flip the Chromebook onto its back, where there are eleven screws.
    • There are two variations of screws on the back panel:
    • Six 8.7mm screws.
    • Five 6.4mm screws.
    • Using your screwdriver with the J00 Phillips Head tip, remove the screws by turning them counter clockwise.
  2. Asus Chromebook C300MA-EDU LAN Card Replacement: 2 단계, 이미지 1/2 Asus Chromebook C300MA-EDU LAN Card Replacement: 2 단계, 이미지 2/2
    • Once the screws are removed, flip the Chromebook back over.
    • Gently remove the keyboard by starting to lift up on one corner with a plastic opening tool.
    • Follow around the brim of the keyboard until it pops off.
  3. Asus Chromebook C300MA-EDU LAN Card Replacement: 3 단계, 이미지 1/3 Asus Chromebook C300MA-EDU LAN Card Replacement: 3 단계, 이미지 2/3 Asus Chromebook C300MA-EDU LAN Card Replacement: 3 단계, 이미지 3/3
    • Once you remove the keyboard, it will be connected to the CPU with two tabbed connections.
    • Release the connections from the tabs gently by flipping the white flaps up until disconnected.
    • You can now pull the ribbons out from the board and remove the keyboard.
  4. Asus Chromebook C300MA-EDU LAN Card Replacement, Battery: 4 단계, 이미지 1/3 Asus Chromebook C300MA-EDU LAN Card Replacement, Battery: 4 단계, 이미지 2/3 Asus Chromebook C300MA-EDU LAN Card Replacement, Battery: 4 단계, 이미지 3/3
    • Once the keyboard is removed, the battery is located on the bottom portion of the shell.
    • The battery is held in with six 6.5mm screws on opposing sides.
  5. Asus Chromebook C300MA-EDU LAN Card Replacement: 5 단계, 이미지 1/2 Asus Chromebook C300MA-EDU LAN Card Replacement: 5 단계, 이미지 2/2
    • The battery is now held in with a tabbed connection to the CPU on the left side of the board. On the tabbed connection, there is a silver plate.
    • Gently push on the silver plate towards the screen until the plastic connection is free.
    • The tabbed connection should now slide out backwards.
  6. Asus Chromebook C300MA-EDU LAN Card Replacement: 6 단계, 이미지 1/2 Asus Chromebook C300MA-EDU LAN Card Replacement: 6 단계, 이미지 2/2
    • At this point, using the plastic removal tool, lift the battery out of the shell.
  7. Asus Chromebook C300MA-EDU LAN Card Replacement, LAN Card: 7 단계, 이미지 1/3 Asus Chromebook C300MA-EDU LAN Card Replacement, LAN Card: 7 단계, 이미지 2/3 Asus Chromebook C300MA-EDU LAN Card Replacement, LAN Card: 7 단계, 이미지 3/3
    • Placing the Chromebook in the upright position, the LAN card is located on the upper right side of the shell.
    • The LAN card is pinned down with 2 coaxial connectors: main power and auxiliary input.
    • To disconnect, gently pull off the two connections using an upwards motion.
  8. Asus Chromebook C300MA-EDU LAN Card Replacement: 8 단계, 이미지 1/3 Asus Chromebook C300MA-EDU LAN Card Replacement: 8 단계, 이미지 2/3 Asus Chromebook C300MA-EDU LAN Card Replacement: 8 단계, 이미지 3/3
    • On the right side of the LAN card is a 3.4mm Phillips head screw.
    • Using the J0 Phillips Head Tip from your tool kit, remove the screw, turning counter clockwise until the screw is free.
  9. Asus Chromebook C300MA-EDU LAN Card Replacement: 9 단계, 이미지 1/2 Asus Chromebook C300MA-EDU LAN Card Replacement: 9 단계, 이미지 2/2
    • At this point, the LAN card is only connected to the CPU.
    • To remove, gently slide out the LAN card from the CPU’s input clip.
    • The LAN card is now disconnected.
결론
Christopher Hart
회원 가입일: 09/28/17
501 평판
안내서 5개 작성하였습니다
USF Tampa, Team S2-G3, Nance Fall 2017 USF Tampa, Team S2-G3, Nance Fall 2017 회원
USFT-NANCE-F17S2G3
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 152
