주요 콘텐츠로 건너뛰기
Asus Chromebook C300SA-DS02 LED Screen Replacement
필요한 것
  1. Asus Chromebook C300SA-DS02 LED Screen Replacement, Keyboard: 1 단계, 이미지 1/2 Asus Chromebook C300SA-DS02 LED Screen Replacement, Keyboard: 1 단계, 이미지 2/2
    • Power the laptop off and make sure the charger is unplugged before starting.
    • Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
    • Remove the three 6.0mm Phillips #0 screws.
  2. Asus Chromebook C300SA-DS02 LED Screen Replacement: 2 단계, 이미지 1/3 Asus Chromebook C300SA-DS02 LED Screen Replacement: 2 단계, 이미지 2/3 Asus Chromebook C300SA-DS02 LED Screen Replacement: 2 단계, 이미지 3/3
    • Open the laptop.
    • Using an iFixit opening tool, pry along the edges of the keyboard.
    • Lift the keyboard and slide it gently towards you.
    • Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
  3. Asus Chromebook C300SA-DS02 LED Screen Replacement: 3 단계, 이미지 1/3 Asus Chromebook C300SA-DS02 LED Screen Replacement: 3 단계, 이미지 2/3 Asus Chromebook C300SA-DS02 LED Screen Replacement: 3 단계, 이미지 3/3
    • Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
  4. Asus Chromebook C300SA-DS02 LED Screen Replacement: 4 단계, 이미지 1/1
    • Remove the keyboard from the laptop.
  5. Asus Chromebook C300SA-DS02 LED Screen Replacement, Battery: 5 단계, 이미지 1/2 Asus Chromebook C300SA-DS02 LED Screen Replacement, Battery: 5 단계, 이미지 2/2
    • Remove the six 5.6mm Phillips #0 screws around the battery.
  6. Asus Chromebook C300SA-DS02 LED Screen Replacement: 6 단계, 이미지 1/2 Asus Chromebook C300SA-DS02 LED Screen Replacement: 6 단계, 이미지 2/2
    • Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
  7. Asus Chromebook C300SA-DS02 LED Screen Replacement: 7 단계, 이미지 1/1
    • Lift the battery out of the laptop.
  8. Asus Chromebook C300SA-DS02 LED Screen Replacement, LED Screen: 8 단계, 이미지 1/2 Asus Chromebook C300SA-DS02 LED Screen Replacement, LED Screen: 8 단계, 이미지 2/2
    • Unplug the black and white cable from the motherboard.
    • These two wires connect to the antenna within the display assembly. The white cable is longer and connects to the bottom import.
  9. Asus Chromebook C300SA-DS02 LED Screen Replacement: 9 단계, 이미지 1/1
    • Peel back the tape covering the plug.
    • Slide the cable towards the screen and out of the input.
  10. Asus Chromebook C300SA-DS02 LED Screen Replacement: 10 단계, 이미지 1/1
    • Unscrew the 6 screws (5 millimeter) on the top right and left.
  11. Asus Chromebook C300SA-DS02 LED Screen Replacement: 11 단계, 이미지 1/1
    • Gently lift the screen up and away from the laptop.
  12. Asus Chromebook C300SA-DS02 LED Screen Replacement: 12 단계, 이미지 1/1
    • Pry off the face panel on the screen using the blue prying tool.
  13. Asus Chromebook C300SA-DS02 LED Screen Replacement: 13 단계, 이미지 1/1
    • Remove the four 2mm Phillips #0 screws from the four corners of the screen.
  14. Asus Chromebook C300SA-DS02 LED Screen Replacement: 14 단계, 이미지 1/2 Asus Chromebook C300SA-DS02 LED Screen Replacement: 14 단계, 이미지 2/2
    • Gently lift screen
    • Peel back the adhesive covering the cable.
    • Remove the cable to free the screen.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Celina Monteiro
회원 가입일: 10/17/17
224 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S1-G7, Simcock Fall 2017 UMass Dartmouth, Team S1-G7, Simcock Fall 2017 회원
UMASSD-SIMCOCK-F17S1G7
3 회원들
안내서 9개 작성하였습니다
댓글 한 개
I used this honestly I broke the screen and some of the wires in the screen are severed. Now I know for sure where the wires go and how to deconstruct it. Thank you so much!
Glorybringers Child - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 11
전체 시간: 696
