소개
If your Asus Chromebook C300SA-DS02 WiFi card has been damaged, use this guide to replace it. Prior to replacing the wireless card, you will need to remove the back cover and keyboard and disconnect the battery for safety.
도구
부품
지정된 부품이 없습니다.
Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
Remove the three 6.0mm Phillips #0 screws.
Use the spudger to pop the black and white coaxial WiFi cables up from the WiFi card.
다른 한 분이 해당 안내서를 완성하였습니다.
