주요 콘텐츠로 건너뛰기
Asus Chromebook C523N Battery Replacement
필요한 것
  1. Asus Chromebook C523N Battery Replacement, Back Cover: 1 단계, 이미지 1/2 Asus Chromebook C523N Battery Replacement, Back Cover: 1 단계, 이미지 2/2
    • Remove the four 0.5mm JIS #00 screws from the bottom edge of the Chromebook and one in the center.
    • Remove the six 1.7mm JIS #00 screws from the sides and top edge of the Chromebook.
  2. Asus Chromebook C523N Battery Replacement: 2 단계, 이미지 1/2 Asus Chromebook C523N Battery Replacement: 2 단계, 이미지 2/2
    • Using a spudger, lift the top left base pad and remove it to reveal a final screw underneath.
    • Remove the one 0.5mm JIS #00 screw underneath the base pad.
  3. Asus Chromebook C523N Battery Replacement: 3 단계, 이미지 1/2 Asus Chromebook C523N Battery Replacement: 3 단계, 이미지 2/2
    • Use an opening tool to gently pry the base enclosure up and remove from the laptop.
  4. Asus Chromebook C523N Battery Replacement, Battery: 4 단계, 이미지 1/3 Asus Chromebook C523N Battery Replacement, Battery: 4 단계, 이미지 2/3 Asus Chromebook C523N Battery Replacement, Battery: 4 단계, 이미지 3/3
    • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small locking flap.
    • Gently disconnect the battery cable from the motherboard.
  5. Asus Chromebook C523N Battery Replacement: 5 단계, 이미지 1/2 Asus Chromebook C523N Battery Replacement: 5 단계, 이미지 2/2
    • Remove six 1.4 mm JIS #00 screws from the battery.
  6. Asus Chromebook C523N Battery Replacement: 6 단계, 이미지 1/1
    • Remove the battery from the laptop.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Aaron Hogan
회원 가입일: 10/15/19
682 평판
안내서 4개 작성하였습니다
댓글 3개
Hi, thank you for this tutorial.
I’ve tried to remove the battery myself but I’ve made a mistake on step 4 while trying to disconnect the cord from the motherboard. By pushing too hard, i’ve unsoldered from the motherboard the black item the cord plugs into. Do you think it can be soldered back by a professional ? If not, can it be replaced ? Thanks in advance,
Julien Guézennec - 답글
Hi, the %#*@ same thing happened to me too. Could u solve it with a professional?
Regards
Mike Soup -
Hey, I replaced the battery is a new one, but when I plug it in the orange light starts flashing but the laptop does start and when I plug in the charger it keeps flashing. Don't know what the problem is. It did work without a battery for a while because I had to order it, can someone help?
Christopher Verbist - 답글
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 33
30일 전: 146
전체 시간: 8,781
