주요 콘텐츠로 건너뛰기
Asus Chromebook C523N Speaker Replacement
필요한 것
  1. Asus Chromebook C523N Speaker Replacement, Back Cover: 1 단계, 이미지 1/2 Asus Chromebook C523N Speaker Replacement, Back Cover: 1 단계, 이미지 2/2
    • Remove the four 0.5mm JIS #00 screws from the bottom edge of the Chromebook and one in the center.
    • Remove the six 1.7mm JIS #00 screws from the sides and top edge of the Chromebook.
  2. Asus Chromebook C523N Speaker Replacement: 2 단계, 이미지 1/2 Asus Chromebook C523N Speaker Replacement: 2 단계, 이미지 2/2
    • Using a spudger, lift the top left base pad and remove it to reveal a final screw underneath.
    • Remove the one 0.5mm JIS #00 screw underneath the base pad.
  3. Asus Chromebook C523N Speaker Replacement: 3 단계, 이미지 1/2 Asus Chromebook C523N Speaker Replacement: 3 단계, 이미지 2/2
    • Use an opening tool to gently pry the base enclosure up and remove from the laptop.
  4. Asus Chromebook C523N Speaker Replacement, Speaker: 4 단계, 이미지 1/3 Asus Chromebook C523N Speaker Replacement, Speaker: 4 단계, 이미지 2/3 Asus Chromebook C523N Speaker Replacement, Speaker: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using the nylon tipped tweezers, gently pry the black and white wires from the wireless card and lift.
  5. Asus Chromebook C523N Speaker Replacement: 5 단계, 이미지 1/3 Asus Chromebook C523N Speaker Replacement: 5 단계, 이미지 2/3 Asus Chromebook C523N Speaker Replacement: 5 단계, 이미지 3/3
    • Use a spudger to pry the small tangle of black, red, white, and blue wires from the audio connector, pushing the wires back toward the speaker.
  6. Asus Chromebook C523N Speaker Replacement: 6 단계, 이미지 1/2 Asus Chromebook C523N Speaker Replacement: 6 단계, 이미지 2/2
    • Use a spudger to pry the black wire from the audio connector, pushing the wires back toward the left speaker.
  7. Asus Chromebook C523N Speaker Replacement: 7 단계, 이미지 1/1
    • Gently grab both speakers and lift them from the Chromebook to remove.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Aaron Hogan
회원 가입일: 10/15/19
682 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 16
전체 시간: 614
