주요 콘텐츠로 건너뛰기
Asus Chromebook C523N Touchpad Replacement
필요한 것
  1. Asus Chromebook C523N Touchpad Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Asus Chromebook C523N Touchpad Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Remove the four 0.5mm JIS #00 screws from the bottom edge of the Chromebook and one in the center.
    • Remove the six 1.7mm JIS #00 screws from the sides and top edge of the Chromebook.
  2. Asus Chromebook C523N Touchpad Replacement: 2 단계, 이미지 2개 중 1개 Asus Chromebook C523N Touchpad Replacement: 2 단계, 이미지 2개 중 2개
    • Using a spudger, lift the top left base pad and remove it to reveal a final screw underneath.
    • Remove the one 0.5mm JIS #00 screw underneath the base pad.
  3. Asus Chromebook C523N Touchpad Replacement: 3 단계, 이미지 2개 중 1개 Asus Chromebook C523N Touchpad Replacement: 3 단계, 이미지 2개 중 2개
    • Use an opening tool to gently pry the base enclosure up and remove from the laptop.
  4. Asus Chromebook C523N Touchpad Replacement, Battery: 4 단계, 이미지 3개 중 1개 Asus Chromebook C523N Touchpad Replacement, Battery: 4 단계, 이미지 3개 중 2개 Asus Chromebook C523N Touchpad Replacement, Battery: 4 단계, 이미지 3개 중 3개
    • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small locking flap.
    • Gently disconnect the battery cable from the motherboard.
  5. Asus Chromebook C523N Touchpad Replacement: 5 단계, 이미지 2개 중 1개 Asus Chromebook C523N Touchpad Replacement: 5 단계, 이미지 2개 중 2개
    • Remove six 1.4 mm JIS #00 screws from the battery.
  6. Asus Chromebook C523N Touchpad Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the battery from the laptop.
  7. Asus Chromebook C523N Touchpad Replacement, Touchpad: 7 단계, 이미지 1개 중 1개
    • Pull gently on the touchpad cable connector to disconnect.
  8. Asus Chromebook C523N Touchpad Replacement: 8 단계, 이미지 1개 중 1개
    • Carefully, remove the tape from the touch pad only.
  9. Asus Chromebook C523N Touchpad Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the three 1.4 mm JIS #00 screws.
  10. Asus Chromebook C523N Touchpad Replacement: 10 단계, 이미지 2개 중 1개 Asus Chromebook C523N Touchpad Replacement: 10 단계, 이미지 2개 중 2개
    • Lift at the far edge of the touchpad to remove it.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Charlotte Arkwright
회원 가입일: 10/17/19
169 평판
안내서 1개를 작성함
3가이드 댓글
Where do i buy the replacement touch pad
Anthony hughs - 답글
Very precise and clear. Thank you.
Raymond Trail - 답글
very clear instructions and photos. It was Easy, as described! One repairer had advised I buy a new Chromebook, bought an unused touchpad for £11. It took me a bit longer than the estimated 15 minutes, but this was the first time I’ve ever had the back off a laptop and attempted a repair/replacement, so took loads of photo’s on the way and took my time. I’ll definitely consider another DIY repair in the future.
John Outhwaite - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 17
전체 시간: 1,100
