주요 콘텐츠로 건너뛰기
Asus Chromebook Flip C100 Lower Case Replacement
필요한 것
  1. Asus Chromebook Flip C100 Lower Case Replacement, Lower Case: 1 단계, 이미지 1/1
    • Unscrew the eight bottom cover screws (one of them is under the hand) using a screwdriver with a J1000 tip.
    • Unscrew the middle screw towards the top of the device using a screwdriver with a T5 tip.
  2. Asus Chromebook Flip C100 Lower Case Replacement: 2 단계, 이미지 1/1
    • Use the plastic opening tool to remove the four bottom rubber feet.
  3. Asus Chromebook Flip C100 Lower Case Replacement: 3 단계, 이미지 1/1
    • Unscrew the four screws under the feet using a screwdriver with a J100 tip.
  4. Asus Chromebook Flip C100 Lower Case Replacement: 4 단계, 이미지 1/1
    • Use the plastic opening tool to pry up the palm rest assembly.
  5. Asus Chromebook Flip C100 Lower Case Replacement: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Disconnect the two cables from the motherboard with tweezers
결론
다른 11명이 해당 안내서를 완성하였습니다.
Jesse Ye
회원 가입일: 06/27/16
527 평판
안내서 1개 작성함
Eastern Washington University, Team 1-1, Rowley SU 2016 Eastern Washington University, Team 1-1, Rowley SU 2016 회원
EWU-ROWLEY-SU16S1G1
3 회원들
안내서 4개 작성하였습니다
댓글 한 개
great guide, though i found the nine screws on the outside required a t5 tip, while the 5 under the feet looked like they were either j100 or j1000, but a philips head worked.
Matthew Sylvester - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 13
전체 시간: 5,137
