주요 콘텐츠로 건너뛰기
Asus Chromebook Flip C100P Power and Volume Buttons Replacement
필요한 것
  1. Asus Chromebook Flip C100P Power and Volume Buttons Replacement, Power and Volume Buttons: 1 단계, 이미지 1/1
    • Remove three of the rubber feet on the bottom cover with a plastic or metal spudger.
  2. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 2 단계, 이미지 1/1
    • Remove the five screws from beneath the rubber feet using a philips head screwdriver. The first 1.9mm screw is located under the front right foot, the second 1.9mm screw and third 2.3mm screw are located under the rear right foot, and the fourth and fifth 2.3mm screws are located under the rear left foot.
  3. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 3 단계, 이미지 1/1
    • Remove the eight 3mm bottom cover screws and one 6mm screw using a T5 screwdriver. Set apart the screw in the rear middle of the bottom cover from the the other eight screws, as it is longer than them.
  4. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 4 단계, 이미지 1/3 Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 4 단계, 이미지 2/3 Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 4 단계, 이미지 3/3
    • Pry the palm rest assembly apart from the bottom cover using a spudger. This step may require a bit of elbow grease. Once the palm rest has been separated from the bottom cover, pull it away from the screen, rather than away from yourself.
  5. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 5 단계, 이미지 1/3 Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 5 단계, 이미지 2/3 Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 5 단계, 이미지 3/3
    • Disconnect the touchpad cable and the keyboard cable on the palm rest assembly from the motherboard using the pointed end of a plastic spudger.
  6. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 6 단계, 이미지 1/2 Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 6 단계, 이미지 2/2
    • Flip up the white part of the connector using the pointed end of a plastic spudge.
  7. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 7 단계, 이미지 1/1
    • Pull the cable out by the blue tab.
  8. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 8 단계, 이미지 1/1
    • Unscrew two 2.7 mm screws using the Phillips #0 screwdriver.
  9. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 9 단계, 이미지 1/1
    • Remove the button chip.
  10. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 10 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Using tweezers, carefully pull out the external buttons.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Andrew Thomson
회원 가입일: 03/19/18
181 평판
안내서 1개 작성함
Baylor, Team S5-G2, Williams Spring 2018 Baylor, Team S5-G2, Williams Spring 2018 회원
BU-WILLIAMS-S18S5G2
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 14
전체 시간: 784
