주요 콘텐츠로 건너뛰기
Asus Chromebook Flip C302CA Display Replacement
필요한 것
  1. Asus Chromebook Flip C302CA Display Replacement, Back Panel: 1 단계, 이미지 1/1
    • Turn the laptop over so the bottom is facing you.
  2. Asus Chromebook Flip C302CA Display Replacement: 2 단계, 이미지 1/3 Asus Chromebook Flip C302CA Display Replacement: 2 단계, 이미지 2/3 Asus Chromebook Flip C302CA Display Replacement: 2 단계, 이미지 3/3
    • Remove two rubber caps on the top.
    • Remove the two 1 mm screws using the Phillips #00 screwdriver.
  3. Asus Chromebook Flip C302CA Display Replacement: 3 단계, 이미지 1/3 Asus Chromebook Flip C302CA Display Replacement: 3 단계, 이미지 2/3 Asus Chromebook Flip C302CA Display Replacement: 3 단계, 이미지 3/3
    • Remove the ten 2 mm screws from the back panel using a T5 Torx screwdriver.
    • Carefully remove the back panel using an opening pick.
  4. Asus Chromebook Flip C302CA Display Replacement: 4 단계, 이미지 1/2 Asus Chromebook Flip C302CA Display Replacement: 4 단계, 이미지 2/2
    • Remove the back panel from the laptop.
  5. Asus Chromebook Flip C302CA Display Replacement, Display: 5 단계, 이미지 1/1
    • Remove the black display ports from the motherboard.
  6. Asus Chromebook Flip C302CA Display Replacement: 6 단계, 이미지 1/1
    • Remove the six 2.54 mm Phillips screws from the left and right screen hinge brackets.
  7. Asus Chromebook Flip C302CA Display Replacement: 7 단계, 이미지 1/1
    • Remove the display unit.
  8. Asus Chromebook Flip C302CA Display Replacement: 8 단계, 이미지 1/1
    • Use heat gun to loosen up adhesive on rubber covers for screw.
  9. Asus Chromebook Flip C302CA Display Replacement: 9 단계, 이미지 1/1
    • Remove rubber covers.
  10. Asus Chromebook Flip C302CA Display Replacement: 10 단계, 이미지 1/1
    • Remove the two 2.5 mm screws.
  11. Asus Chromebook Flip C302CA Display Replacement: 11 단계, 이미지 1/1
    • Use prying tool to separate panel from monitor.
  12. Asus Chromebook Flip C302CA Display Replacement: 12 단계, 이미지 1/1
    • Remove this connection by pulling to separate it from the monitor.
  13. Asus Chromebook Flip C302CA Display Replacement: 13 단계, 이미지 1/1
    • Remove connection point and the entire camera assembly including wires.
결론
NICKO SANTOS SALEM
회원 가입일: 10/03/22
529 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 19
전체 시간: 290
