주요 콘텐츠로 건너뛰기
Asus Chromebook Flip C302CA Mother & Daughterboard Replacement
필요한 것
  1. Asus Chromebook Flip C302CA Mother & Daughterboard Replacement, Mother & Daughterboard: 1 단계, 이미지 1/1
    • With the T5 Torx Screwdriver, remove the ten 5 mm screws from the back panel.
    • Remove the rubber caps at the top of the panel. Then, using the Phillips #00 Screwdriver, remove the two 1 mm screws underneath.
    • Lift up the back panel.
  2. Asus Chromebook Flip C302CA Mother & Daughterboard Replacement: 2 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Using Tweezers, carefully remove the black wire connected to the audio card.
    • Repeat this process for the white wire.
  3. Asus Chromebook Flip C302CA Mother & Daughterboard Replacement: 3 단계, 이미지 1/1
    • Remove the four 2.5 mm screws securing the battery
    • Remove the connector from the motherboard by pulling straight up on it.
    • Carefully lift the battery out of the laptop.
  4. Asus Chromebook Flip C302CA Mother & Daughterboard Replacement: 4 단계, 이미지 1/1
    • Remove the highlighted strips connected to the top of the display.
  5. Asus Chromebook Flip C302CA Mother & Daughterboard Replacement: 5 단계, 이미지 1/1
    • Gently lift the white tab highlighted in the image. Then, disconnect the blue connector by pulling away from the motherboard.
  6. Asus Chromebook Flip C302CA Mother & Daughterboard Replacement: 6 단계, 이미지 1/1
    • Gently lift the black tab highlighted in the photo. Then, repeat the same process mentioned above.
  7. Asus Chromebook Flip C302CA Mother & Daughterboard Replacement: 7 단계, 이미지 1/1
    • Once again, lift the white tab highlighted in the image. Then, pull the brown connector away to disconnect it from the motherboard.
  8. Asus Chromebook Flip C302CA Mother & Daughterboard Replacement: 8 단계, 이미지 1/1
    • With the Phillips #00 Screwdriver, remove the two highlighted 1 mm screws attaching the heatsink (highlighted in orange) to the motherboard.
    • Then, remove the heatsink from the motherboard.
  9. Asus Chromebook Flip C302CA Mother & Daughterboard Replacement: 9 단계, 이미지 1/1
    • With the Philips-Head #00 Screwdriver, remove the eleven 2.5 mm screws that secure the motherboard.
    • With the same tool, remove the four 1.3 mm screws at the bottom of the mother board/daughterboard.
    • Replace the motherboard/daughterboard.
결론
NICKO SANTOS SALEM
회원 가입일: 10/03/22
529 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 20
전체 시간: 203
