주요 콘텐츠로 건너뛰기
Asus EEE PC 1000HD Keyboard Replacement
필요한 것
  1. Asus EEE PC 1000HD Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Note: Prior to changing the keyboard on your laptop, be sure to have a replacement keyboard on hand.
  2. Asus EEE PC 1000HD Keyboard Replacement: 2 단계, 이미지 1/2 Asus EEE PC 1000HD Keyboard Replacement: 2 단계, 이미지 2/2
    • Use a metal spudger and carefully insert the end of the flat tip into the edge of the keyboard.
    • Hold one end of the keyboard down to make prying easier.
    • Gently lift the metal spudger until you begin hearing clicking noises; these are the sounds of the keyboard unclasping from the board below.
  3. Asus EEE PC 1000HD Keyboard Replacement: 3 단계, 이미지 1/1
    • Once you lift the keyboard, there will be a metal tab that connects the keyboard to the metal panel below.
    • Detach this metal tab slowly.
  4. Asus EEE PC 1000HD Keyboard Replacement: 4 단계, 이미지 1/1
    • The keyboard should be fully detached.
    • With your new replacement keyboard, insert the metal tab back into the metal panel. Press gently on the keyboard to lock it into place.
    • There should be a few clicking noises as the new keyboard latches onto the metal board.
결론
Emily Gao
회원 가입일: 10/17/17
101 평판
안내서 1개 작성함
UC Santa Barbara, Team S2-G6, Weedon Fall 2017 UC Santa Barbara, Team S2-G6, Weedon Fall 2017 회원
UCSB-WEEDON-F17S2G6
5 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 16
전체 시간: 553
