소개
Follow this guide if you need to replace your netbook's hard drive. Back up any important data so that you can transfer it to the new hard drive.
필요한 것
Lay the laptop down with the bottom facing upwards.
Locate the two battery lock slide tabs.
Using the Ph00 (+) Phillips screw head, unscrew the two 4 mm screws that hold the back panel in place.
Use the spudger to gently pry off the back panel.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 한 개
This guide used to have 8 steps as of 2017-06-19. I have edited out step 6 because it is unnecessary and risks damaging the hard drive. The screws on top of the hard drive should never be taken out outside of specialist situations such as data recovery. Removing the screws along the sides is all that is needed to remove the drive from the metal casing. Do not follow step 6 if there are still 8 steps displayed!
azureskies - 답글
