주요 콘텐츠로 건너뛰기
Asus Eee PC 1000HE Hard Drive Replacement
필요한 것
  1. Asus Eee PC 1000HE Hard Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Lay the laptop down with the bottom facing upwards.
    • Locate the two battery lock slide tabs.
  2. Asus Eee PC 1000HE Hard Drive Replacement: 2 단계, 이미지 2개 중 1개 Asus Eee PC 1000HE Hard Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the tabs outward to unlock the battery.
    • The right tab will remain in the unlocked position while the left tab must be held.
    • While holding the left tab outward, slide the battery away from you to remove it.
  3. Asus Eee PC 1000HE Hard Drive Replacement, Hard Drive: 3 단계, 이미지 2개 중 1개 Asus Eee PC 1000HE Hard Drive Replacement, Hard Drive: 3 단계, 이미지 2개 중 2개
    • Using the Ph00 (+) Phillips screw head, unscrew the two 4 mm screws that hold the back panel in place.
    • Use the spudger to gently pry off the back panel.
  4. Asus Eee PC 1000HE Hard Drive Replacement: 4 단계, 이미지 2개 중 1개 Asus Eee PC 1000HE Hard Drive Replacement: 4 단계, 이미지 2개 중 2개
    • Use the PH00 (+) screw head and screw driver to remove the 4 mm screw holding down the hard drive cover.
    • The hard drive cover is the silver plate on top of the hard drive.
  5. Asus Eee PC 1000HE Hard Drive Replacement: 5 단계, 이미지 2개 중 1개 Asus Eee PC 1000HE Hard Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Slide the hard drive from the left towards the right side to detach it
    • Once the hard drive is detached, lift the black tab and remove from the netbook.
    • Do not continue with the next 3 steps if you are not attempting to replace your hard drive. Proceed to the next section instead.
  6. Asus Eee PC 1000HE Hard Drive Replacement: 6 단계, 이미지 2개 중 1개 Asus Eee PC 1000HE Hard Drive Replacement: 6 단계, 이미지 2개 중 2개
    • Do not continue with this step or the next two steps if replacing the hard drive is not the goal. For all other guides, simply removing the hard drive from the PC (shown in previous steps) is the only necessary step.
    • To remove the metal hard drive casing, use a T6 (star head) screwdriver head to remove six 4mm screws marked by the red circles in the picture.
  7. Asus Eee PC 1000HE Hard Drive Replacement: 7 단계, 이미지 3개 중 1개 Asus Eee PC 1000HE Hard Drive Replacement: 7 단계, 이미지 3개 중 2개 Asus Eee PC 1000HE Hard Drive Replacement: 7 단계, 이미지 3개 중 3개
    • Next, remove the two 4mm screws on each side of the hard drive case shown by the blue circles. Use the PH00 (+) Philips head and screwdriver head used in the previous step to remove these 4 mm screws.
    • There should be 4 total screws, 2 on each side.
  8. Asus Eee PC 1000HE Hard Drive Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the hard drive from the metal casing by lifting it up.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Mike Glenn
회원 가입일: 03/21/16
1,014 평판
안내서 8개를 작성함
Clemson, Team 6-2, Benson Spring 2016 Clemson, Team 6-2, Benson Spring 2016 회원
CLEM-BENSON-S16S6G2
4 회원들
안내서 18개를 작성함
댓글 한 개
This guide used to have 8 steps as of 2017-06-19. I have edited out step 6 because it is unnecessary and risks damaging the hard drive. The screws on top of the hard drive should never be taken out outside of specialist situations such as data recovery. Removing the screws along the sides is all that is needed to remove the drive from the metal casing. Do not follow step 6 if there are still 8 steps displayed!
azureskies - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 47
전체 시간: 2,558
