이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
A faulty Bluetooth Module can cause delayed or no connection to peripheral wireless devices such as mice, headsets, and microphones. If the problem cannot be solved by installing an update, replacement may be necessary. Follow this guide to replace your Bluetooth Module. Note: Before beginning this guide, remove the battery by referring to the Battery Replacement Guide.
필요한 것
Use a plastic opening tool to pull up the four metal latches in the battery cavity that is located on the bottom of the laptop.
Flip the laptop over.
Using a Phillips #1 screwdriver, remove the five 5.65 mm screws.
Detach the five plastic clips holding the upper and lower halves of the laptop together. These can be undone by carefully running a plastic opening tool between the top and bottom casing. There will be an audible audible "click" as the clips come undone.
Once the five clips have been undone, carefully remove the upper half of the laptop.
