이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use a plastic opening tool to pull up the four metal latches in the battery cavity that is located on the bottom of the laptop.
Flip the laptop over, and open the display.
Use a plastic opening tool to lift the edge of the keyboard that is nearest to the screen.
Gently lift the keyboard and slide it toward the screen.
Use a spudger tool to release the tabs on the ribbon cable ZIF connector that is attached to the underside of the keyboard.
Once the ZIF connector tabs have been released, remove the keyboard.
Flip the laptop over.
Using a Phillips #1 screwdriver, remove the five 5.65 mm screws.
Remove the lid to the RAM compartment, if possible.
To remove the RAM, depress the tabs that are holding it in. These tabs are bound in red in the picture.
Use a Phillips #1 screwdriver to remove one 6.5 mm screw located next to the RAM.
Flip the laptop back over, and open the display.
Use a Phillips #1 screwdriver to remove the six 5.5 mm screws on the inside covering.
Detach the five plastic clips holding the upper and lower halves of the laptop together. These can be undone by carefully running a plastic opening tool between the top and bottom casing. There will be an audible audible "click" as the clips come undone.
Once the five clips have been undone, carefully remove the upper half of the laptop.
Detach the track pad ribbon by using a plastic opening tool to raise up the black pad.
Detach the Bluetooth wire located below the fan by gently pulling it upward.
