소개
Use this guide to replace or upgrade the hard drive in the Asus Eee PC 1005HA.
The first step is to remove the battery from the laptop.
Use a plastic opening tool to pull up the four metal latches in the battery cavity that is located on the bottom of the laptop.
Flip the laptop over.
Remove the four 5.65 mm screws from the bottom of the case.
Loosen the captive screw in the RAM compartment cover.
다른 45명이 해당 안내서를 완성하였습니다.
댓글 10개
Good guide! Thx!
What's the biggest hard drive that will work on this netbook?
If I remember correctly, from the manufacturer, 500 GB should work. I had a WD 320 GB in it.
