소개
Although there are several ways this task could be accomplished, this guide walks through the most appropriate steps to complete the task without damaging the fragile components. Read instructions carefully to reach success.
필요한 것
Use a plastic opening tool to pull up the four metal latches in the battery cavity that is located on the bottom of the laptop.
Flip the laptop over, and open the display.
Use a plastic opening tool to lift the edge of the keyboard that is nearest to the screen.
Gently lift the keyboard and slide it toward the screen.
It must be mentioned that you need to put the plastic opening tool above the F1, F6, between F10 and F11 and the Insert (Num Lock) Keys . It has 4 clips in total.
Use a spudger tool to release the tabs on the ribbon cable ZIF connector that is attached to the underside of the keyboard.
Once the ZIF connector tabs have been released, remove the keyboard.
Step is missing. you also suppose to remove back screws, then rf shield screws, disconnect touchpad cable and then unclip and lift sides.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
een heel duidelijke uitleg. ik zal het zelf niet proberen. ben bang dat ik met ijn trillende vingers de boel kapot ga maken.
ik had wifi verbinding maar ineens is het niet meer mogelijk om on-line te komen.
de ==internet adopter == werkt niet.
vraag mijn zwager om te helpen, anders moet ik afscheid nemen van mijn kleine computertje.
jammer.
beukeneut@gmail.com
