이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Although there are several ways this task could be accomplished, this guide walks through the most appropriate steps to complete the task without damaging the fragile components. Read instructions carefully to reach success.
필요한 것
Use a plastic opening tool to pull up the four metal latches in the battery cavity that is located on the bottom of the laptop.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
een heel duidelijke uitleg. ik zal het zelf niet proberen. ben bang dat ik met ijn trillende vingers de boel kapot ga maken.
ik had wifi verbinding maar ineens is het niet meer mogelijk om on-line te komen.
de ==internet adopter == werkt niet.
vraag mijn zwager om te helpen, anders moet ik afscheid nemen van mijn kleine computertje.
jammer.
beukeneut@gmail.com
