주요 콘텐츠로 건너뛰기
Asus Eee PC 1005PEB Keyboard Replacement
필요한 것
  1. Asus Eee PC 1005PEB Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Start by placing the laptop upside-down on a flat surface.
    • Find the two clips on the back portion of the laptop.
  2. Asus Eee PC 1005PEB Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Using your finger, push the clip labeled with a "1" on the laptop from the lock position to unlock position.
    • This clip will hold itself, so after you move it to the unlock position you can remove your finger.
  3. Asus Eee PC 1005PEB Keyboard Replacement: 3 단계, 이미지 2개 중 1개 Asus Eee PC 1005PEB Keyboard Replacement: 3 단계, 이미지 2개 중 2개
    • Using your finger, push and hold the pin indicated by a "2" on the laptop from the lock to unlock position.
    • While holding this pin in the unlock position, use your other hand to pull the battery horizontally away from the laptop.
    • When the pins on the battery that reach towards the laptop are away from the laptop, you can release the "2" clip.
  4. Asus Eee PC 1005PEB Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Using both hands, pull the battery horizontally away from the laptop.
  5. Asus Eee PC 1005PEB Keyboard Replacement, Keyboard: 5 단계, 이미지 1개 중 1개
    • Face the laptop so the 4 silver "clips" along the middle of the battery cartridge are in front of you.
  6. Asus Eee PC 1005PEB Keyboard Replacement: 6 단계, 이미지 3개 중 1개 Asus Eee PC 1005PEB Keyboard Replacement: 6 단계, 이미지 3개 중 2개 Asus Eee PC 1005PEB Keyboard Replacement: 6 단계, 이미지 3개 중 3개
    • Using the wide opening tool, unhook each clip from its original position by pulling the clip towards you.
    • Repeat for all four of the clips.
  7. Asus Eee PC 1005PEB Keyboard Replacement: 7 단계, 이미지 1개 중 1개
    • Turn the laptop right side up and lift the lid.
    • Insert the flat end of the spudger into the small gap between the top of the keyboard and the plastic of the laptop.
    • Using the spudger as leverage, lift the keyboard up from the rest of the laptop.
    • Run the spudger across the seam until the entire top edge is exposed. The two sides of the keyboard should also pop up in this process.
  8. Asus Eee PC 1005PEB Keyboard Replacement: 8 단계, 이미지 1개 중 1개
    • The keyboard should now lift from the base of the laptop.
    • Do not lift the keyboard up to quickly or too hard, since a ribbon cable is still attached to the keyboard and doing so could break it.
  9. Asus Eee PC 1005PEB Keyboard Replacement: 9 단계, 이미지 3개 중 1개 Asus Eee PC 1005PEB Keyboard Replacement: 9 단계, 이미지 3개 중 2개 Asus Eee PC 1005PEB Keyboard Replacement: 9 단계, 이미지 3개 중 3개
    • Using the pointed end of the spudger tool, disconnect the ribbon cable that extends from the bottom of the keyboard to the computer by pushing on the connections of the cable.
    • Once the ribbon cable is disconnected, the keyboard can be fully removed by lifting it away from the laptop.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Aaron Arenas
회원 가입일: 04/20/14
751 평판
안내서 5개를 작성함
Cal Poly, Team 13-32, Maness Spring 2014 Cal Poly, Team 13-32, Maness Spring 2014 회원
CPSU-MANESS-S14S13G32
5 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 26
전체 시간: 1,292
