주요 콘텐츠로 건너뛰기
Asus Eee PC 1005PEB RAM Replacement
필요한 것
  1. Asus Eee PC 1005PEB RAM Replacement, RAM: 1 단계, 이미지 2개 중 1개 Asus Eee PC 1005PEB RAM Replacement, RAM: 1 단계, 이미지 2개 중 2개
    • Start by having the laptop upside down on a hard flat surface.
    • Find and unscrew the 6.65 mm Phillips #1 screw.
    • The screw will not detach from the RAM cover.
  2. Asus Eee PC 1005PEB RAM Replacement: 2 단계, 이미지 2개 중 1개 Asus Eee PC 1005PEB RAM Replacement: 2 단계, 이미지 2개 중 2개
    • Carefully remove the cover by lifting it with your fingers.
    • Make sure that you do not pull the cover to quickly or too hard as this could damage the plastic pins that hold the cover on.
  3. Asus Eee PC 1005PEB RAM Replacement: 3 단계, 이미지 2개 중 1개 Asus Eee PC 1005PEB RAM Replacement: 3 단계, 이미지 2개 중 2개
    • Identify the pins on both sides of the RAM.
    • Using both hands, pull the pins apart from each other to release the RAM.
    • The RAM will "pop" up on its own after the pins are pressed.
  4. Asus Eee PC 1005PEB RAM Replacement: 4 단계, 이미지 1개 중 1개
    • Grab the RAM stick with two fingers and gently pull it out of its slot.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Aaron Arenas
회원 가입일: 04/20/14
751 평판
안내서 5개를 작성함
Cal Poly, Team 13-32, Maness Spring 2014 Cal Poly, Team 13-32, Maness Spring 2014 회원
CPSU-MANESS-S14S13G32
5 회원들
안내서 5개를 작성함
댓글 한 개
Everything I've read says you can only upgrade from the 1gb ram to a 2gig. Here's what I just installed: http://amzn.to/2x0flty and so far its working great...I notice a difference in speed, although this thing is still slow.
Dan Fowler - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 29
전체 시간: 1,022
