소개
You will be the remove of the battery and continue to cautiously take the graphics card off of the laptop. This installation would be necessary if a user has a fried, defected, or inoperative in general.
  1. Using the plastic opening tool, carefully pry the top panel from the base.
    • Using the plastic opening tool, carefully pry the top panel from the base.
  2. Lift the side of the keyboard. Disconnect the attached ribbon located underneath the keyboard. Place your index finger in the hole on the right side of the keyboard tray and lift the tray.
    • Lift the side of the keyboard.
    • Disconnect the attached ribbon located underneath the keyboard.
    • Place your index finger in the hole on the right side of the keyboard tray and lift the tray.
  3. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  4. Use your fingers to lift the battery and gently disconnect the wires from the base. Use your fingers to lift the battery and gently disconnect the wires from the base.
    • Use your fingers to lift the battery and gently disconnect the wires from the base.
  5. Remove the two 2mm screws from the graphics card.
    • Remove the two 2mm screws from the graphics card.
  6. Flip over the graphics card. Pull the black plastic locking mechanism towards the golden ribbon to unlock. Pull out the ribbon.
    • Flip over the graphics card.
    • Pull the black plastic locking mechanism towards the golden ribbon to unlock.
    • Pull out the ribbon.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alex Powers
회원 가입일: 2013년 04월 17일
101 평판
안내서 2개 작성하였습니다
Cal Poly, Team 21-52, Johann Spring 2013 Cal Poly, Team 21-52, Johann Spring 2013 회원
CPSU-JOHANN-S13S21G52
4 회원들
안내서 6개 작성하였습니다
Is this the graphics card?
Is this pc has no integrated graphics card?
JUAN LUIS GARCIA BRAVO - 답글
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 16
전체 시간: 2,926
