주요 콘텐츠로 건너뛰기
Asus Eee PC 1008ha Graphics Card Replacement
필요한 것
  1. Asus Eee PC 1008ha Graphics Card Replacement, Battery: 1 단계, 이미지 1/1
    • Using the plastic opening tool, carefully pry the top panel from the base.
  2. Asus Eee PC 1008ha Graphics Card Replacement: 2 단계, 이미지 1/3 Asus Eee PC 1008ha Graphics Card Replacement: 2 단계, 이미지 2/3 Asus Eee PC 1008ha Graphics Card Replacement: 2 단계, 이미지 3/3
    • Lift the side of the keyboard.
    • Disconnect the attached ribbon located underneath the keyboard.
    • Place your index finger in the hole on the right side of the keyboard tray and lift the tray.
  3. Asus Eee PC 1008ha Graphics Card Replacement: 3 단계, 이미지 1/2 Asus Eee PC 1008ha Graphics Card Replacement: 3 단계, 이미지 2/2
    • Use your fingers to lift the battery and gently disconnect the wires from the base.
  4. Asus Eee PC 1008ha Graphics Card Replacement, Graphics Card: 4 단계, 이미지 1/1
    • Remove the two 2mm screws from the graphics card.
  5. Asus Eee PC 1008ha Graphics Card Replacement: 5 단계, 이미지 1/3 Asus Eee PC 1008ha Graphics Card Replacement: 5 단계, 이미지 2/3 Asus Eee PC 1008ha Graphics Card Replacement: 5 단계, 이미지 3/3
    • Flip over the graphics card.
    • Pull the black plastic locking mechanism towards the golden ribbon to unlock.
    • Pull out the ribbon.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alex Powers
회원 가입일: 04/17/13
101 평판
안내서 2개 작성하였습니다
Cal Poly, Team 21-52, Johann Spring 2013 Cal Poly, Team 21-52, Johann Spring 2013 회원
CPSU-JOHANN-S13S21G52
4 회원들
안내서 11개 작성하였습니다
댓글 한 개
Is this the graphics card?
Is this pc has no integrated graphics card?
JUAN LUIS GARCIA BRAVO - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 3,599
