주요 콘텐츠로 건너뛰기
Asus Eee PC 1008ha Screen Replacement
필요한 것
  1. Asus Eee PC 1008ha Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Using the plastic opening tool, carefully pry the top panel from the base.
  2. Asus Eee PC 1008ha Screen Replacement: 2 단계, 이미지 1/3 Asus Eee PC 1008ha Screen Replacement: 2 단계, 이미지 2/3 Asus Eee PC 1008ha Screen Replacement: 2 단계, 이미지 3/3
    • Lift the side of the keyboard.
    • Disconnect the attached ribbon located underneath the keyboard.
    • Place your index finger in the hole on the right side of the keyboard tray and lift the tray.
  3. Asus Eee PC 1008ha Screen Replacement: 3 단계, 이미지 1/2 Asus Eee PC 1008ha Screen Replacement: 3 단계, 이미지 2/2
    • Use your fingers to lift the battery and gently disconnect the wires from the base.
  4. Asus Eee PC 1008ha Screen Replacement, LCD Screen: 4 단계, 이미지 1/2 Asus Eee PC 1008ha Screen Replacement, LCD Screen: 4 단계, 이미지 2/2
    • Using the Phillips #00 screwdriver, unscrew the 4mm screws from the rightmost circuit board.
    • Carefully pull the circuit board away from side of device base.
  5. Asus Eee PC 1008ha Screen Replacement: 5 단계, 이미지 1/3 Asus Eee PC 1008ha Screen Replacement: 5 단계, 이미지 2/3 Asus Eee PC 1008ha Screen Replacement: 5 단계, 이미지 3/3
    • Using the Phillips #00 screwdriver, unscrew the 4mm screws attaching screen to base from both sides.
    • Gently lift the screen portion from the base.
  6. Asus Eee PC 1008ha Screen Replacement: 6 단계, 이미지 1/2 Asus Eee PC 1008ha Screen Replacement: 6 단계, 이미지 2/2
    • Using the Plastic Opening Tool, pry the six small chits from the face of the screen portion.
    • Using the Phillips #00 screwdriver, unscrew the two 2mm and four 4mm screws from underneath the chits.
  7. Asus Eee PC 1008ha Screen Replacement: 7 단계, 이미지 1/2 Asus Eee PC 1008ha Screen Replacement: 7 단계, 이미지 2/2
    • Slide the Plastic Opening Tool under the edge of the screen bezel to release the front panel of the screen.
  8. Asus Eee PC 1008ha Screen Replacement: 8 단계, 이미지 1/2 Asus Eee PC 1008ha Screen Replacement: 8 단계, 이미지 2/2
    • Using the Phillips #00 screwdriver, unscrew the 2mm screws from the perimeter of the screen.
    • Use your fingers to hold the screen and carefully lift it from the base.
  9. Asus Eee PC 1008ha Screen Replacement: 9 단계, 이미지 1/2 Asus Eee PC 1008ha Screen Replacement: 9 단계, 이미지 2/2
    • Use your fingers to peel back the adhesive tape located on the back of the screen.
    • Disconnect the wire from the screen.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Michael Dooley
회원 가입일: 04/18/13
138 평판
안내서 3개 작성하였습니다
Cal Poly, Team 21-52, Johann Spring 2013 Cal Poly, Team 21-52, Johann Spring 2013 회원
CPSU-JOHANN-S13S21G52
4 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 16
전체 시간: 3,075
