이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Using the plastic opening tool, carefully pry the top panel from the base.
Lift the side of the keyboard.
Disconnect the attached ribbon located underneath the keyboard.
Place your index finger in the hole on the right side of the keyboard tray and lift the tray.
Use your fingers to lift the battery and gently disconnect the wires from the base.
Using the Phillips #00 screwdriver, unscrew the 4mm screws from the rightmost circuit board.
Carefully pull the circuit board away from side of device base.
Using the Phillips #00 screwdriver, unscrew the 4mm screws attaching screen to base from both sides.
Gently lift the screen portion from the base.
Using the Plastic Opening Tool, pry the six small chits from the face of the screen portion.
Using the Phillips #00 screwdriver, unscrew the two 2mm and four 4mm screws from underneath the chits.
Slide the Plastic Opening Tool under the edge of the screen bezel to release the front panel of the screen.
Using the Phillips #00 screwdriver, unscrew the 2mm screws from the perimeter of the screen.
Use your fingers to hold the screen and carefully lift it from the base.
Use your fingers to peel back the adhesive tape located on the back of the screen.
Disconnect the wire from the screen.
다른 한 분이 해당 안내서를 완성하였습니다.
