주요 콘텐츠로 건너뛰기
Asus Eee PC 1201HAB Hard Drive Replacement
필요한 것
  1. Asus Eee PC 1201HAB Hard Drive Replacement, Keyboard: 1 단계, 이미지 1/2 Asus Eee PC 1201HAB Hard Drive Replacement, Keyboard: 1 단계, 이미지 2/2
    • Use a plastic opening tool and carefully pry the top panel from the base.
  2. Asus Eee PC 1201HAB Hard Drive Replacement: 2 단계, 이미지 1/3 Asus Eee PC 1201HAB Hard Drive Replacement: 2 단계, 이미지 2/3 Asus Eee PC 1201HAB Hard Drive Replacement: 2 단계, 이미지 3/3
    • Slowly lift the keyboard from the base.
    • Disconnect the attached ribbon from under the keyboard.
  3. Asus Eee PC 1201HAB Hard Drive Replacement: 3 단계, 이미지 1/1
    • Remove the keyboard.
  4. Asus Eee PC 1201HAB Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/2 Asus Eee PC 1201HAB Hard Drive Replacement, Hard Drive: 4 단계, 이미지 2/2
    • Lay the laptop with the back facing up.
    • With a Phillips #0 screwdriver, remove the eight 6mm screws on the back of the laptop.
  5. Asus Eee PC 1201HAB Hard Drive Replacement: 5 단계, 이미지 1/3 Asus Eee PC 1201HAB Hard Drive Replacement: 5 단계, 이미지 2/3 Asus Eee PC 1201HAB Hard Drive Replacement: 5 단계, 이미지 3/3
    • Slide the tabs outward to remove the battery.
  6. Asus Eee PC 1201HAB Hard Drive Replacement: 6 단계, 이미지 1/2 Asus Eee PC 1201HAB Hard Drive Replacement: 6 단계, 이미지 2/2
    • Flip the device so that you are facing the screen.
    • Remove the ten 4mm screws on the silver panel under the keyboard using a Phillips #0 screwdriver.
  7. Asus Eee PC 1201HAB Hard Drive Replacement: 7 단계, 이미지 1/3 Asus Eee PC 1201HAB Hard Drive Replacement: 7 단계, 이미지 2/3 Asus Eee PC 1201HAB Hard Drive Replacement: 7 단계, 이미지 3/3
    • Using a plastic opening tool, remove the top panel of the laptop.
  8. Asus Eee PC 1201HAB Hard Drive Replacement: 8 단계, 이미지 1/2 Asus Eee PC 1201HAB Hard Drive Replacement: 8 단계, 이미지 2/2
    • Using a Phillips #0 screwdriver, remove the four 4mm screws connecting the hard drive.
  9. Asus Eee PC 1201HAB Hard Drive Replacement: 9 단계, 이미지 1/1
    • Remove and replace the hard drive.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Katherine Chan
회원 가입일: 10/22/18
353 평판
안내서 2개 작성하였습니다
UC Davis, Team S7-G3, Lore Fall 2018 UC Davis, Team S7-G3, Lore Fall 2018 회원
UCD-LORE-F18S7G3
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 34
전체 시간: 790
