주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus Eee PC 1201N Cooling fan replacement
필요한 것
  1. Asus Eee PC 1201N Cooling fan replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Flip the netbook over.
    • Be sure to unplug the netbook and power off the device while working.
  2. Asus Eee PC 1201N Cooling fan replacement: 2 단계, 이미지 1개 중 1개
    • Push open both tabs on either side of the battery.
    • The tab on the left will click open and stay in place until you close it.
  3. Asus Eee PC 1201N Cooling fan replacement: 3 단계, 이미지 1개 중 1개
    • Pull the tab on the right open, while you remove battery with your other hand.
    • Pull the battery straight out ensuring that you don't damage any connectors.
  4. Asus Eee PC 1201N Cooling fan replacement, Keyboard: 4 단계, 이미지 2개 중 1개 Asus Eee PC 1201N Cooling fan replacement, Keyboard: 4 단계, 이미지 2개 중 2개
    • Open the netbook to find the four small grooves along the top of the keyboard.
    • Pry the keyboard up using the plastic opening tool.
  5. Asus Eee PC 1201N Cooling fan replacement: 5 단계, 이미지 2개 중 1개 Asus Eee PC 1201N Cooling fan replacement: 5 단계, 이미지 2개 중 2개
    • Tilt the keyboard away from you to access the connector. Gently push the lock toward the screen to unlock it and slide the ribbon out.
    • Remove the keyboard.
  6. Asus Eee PC 1201N Cooling fan replacement, Cooling fan: 6 단계, 이미지 1개 중 1개
    • Remove the eight 6.5mm screws using the J0 Phillips head screwdriver from back of the netbook.
  7. Asus Eee PC 1201N Cooling fan replacement: 7 단계, 이미지 2개 중 1개 Asus Eee PC 1201N Cooling fan replacement: 7 단계, 이미지 2개 중 2개
    • Remove the ten 4.5 mm screws from cover plate using the J0 Phillips head screwdriver.
    • Remove the cover plate by sliding the plastic opening tool around the entire edge of the plate.
  8. Asus Eee PC 1201N Cooling fan replacement: 8 단계, 이미지 1개 중 1개
    • Pull the blue tab for the touchpad connector before removing the cover plate completely.
  9. Asus Eee PC 1201N Cooling fan replacement: 9 단계, 이미지 1개 중 1개
    • Remove the two 4.6 mm screws from the cover plate using the J0 Phillips head screwdriver.
  10. Asus Eee PC 1201N Cooling fan replacement: 10 단계, 이미지 1개 중 1개
    • Unplug the connector.
  11. Asus Eee PC 1201N Cooling fan replacement: 11 단계, 이미지 1개 중 1개
    • Lift up and remove the fan.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Krishna Janjanam
회원 가입일: 11/08/16
206 평판
안내서 1개를 작성함
USF Tampa, Team 2-3, Nance Fall 2016 USF Tampa, Team 2-3, Nance Fall 2016 회원
USFT-NANCE-F16S2G3
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 5
지난 30일: 48
전체 시간: 1,205
