주요 콘텐츠로 건너뛰기
Asus Eee PC 1201N Hard Drive Replacement
필요한 것
  1. Asus Eee PC 1201N Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the netbook over.
    • Be sure to unplug the netbook and power off the device while working.
  2. Asus Eee PC 1201N Hard Drive Replacement: 2 단계, 이미지 1/1
    • Push open both tabs on either side of the battery.
    • The tab on the left will click open and stay in place until you close it.
  3. Asus Eee PC 1201N Hard Drive Replacement: 3 단계, 이미지 1/1
    • Pull the tab on the right open, while you remove battery with your other hand.
    • Pull the battery straight out ensuring that you don't damage any connectors.
  4. Asus Eee PC 1201N Hard Drive Replacement, Keyboard: 4 단계, 이미지 1/2 Asus Eee PC 1201N Hard Drive Replacement, Keyboard: 4 단계, 이미지 2/2
    • Open the netbook to find the four small grooves along the top of the keyboard.
    • Pry the keyboard up using the plastic opening tool.
  5. Asus Eee PC 1201N Hard Drive Replacement: 5 단계, 이미지 1/2 Asus Eee PC 1201N Hard Drive Replacement: 5 단계, 이미지 2/2
    • Tilt the keyboard away from you to access the connector. Gently push the lock toward the screen to unlock it and slide the ribbon out.
    • Remove the keyboard.
  6. Asus Eee PC 1201N Hard Drive Replacement, Hard Drive: 6 단계, 이미지 1/1
    • Turn the netbook over and remove the eight 6.5mm screws using the J0 Phillips head screwdriver.
  7. Asus Eee PC 1201N Hard Drive Replacement: 7 단계, 이미지 1/2 Asus Eee PC 1201N Hard Drive Replacement: 7 단계, 이미지 2/2
    • Turn the netbook back over and remove the ten 4.5mm screws using the J0 Phillips head screwdriver.
    • Remove the cover plate by sliding the plastic opening tool around the entire edge of the plate.
  8. Asus Eee PC 1201N Hard Drive Replacement: 8 단계, 이미지 1/1
    • Flip up the retaining flap on the ZIF connector. Then, pull the blue tab for the touchpad connector before removing the cover plate completely.
  9. Asus Eee PC 1201N Hard Drive Replacement: 9 단계, 이미지 1/1
    • Remove the four 4.6mm screws with the J0 Phillips head screwdriver.
  10. Asus Eee PC 1201N Hard Drive Replacement: 10 단계, 이미지 1/2 Asus Eee PC 1201N Hard Drive Replacement: 10 단계, 이미지 2/2
    • Slide the hard drive to the right and then lift it straight out of the netbook.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Trae Mikesell
회원 가입일: 10/04/16
394 평판
안내서 3개 작성하였습니다
USF Tampa, Team 2-3, Nance Fall 2016 USF Tampa, Team 2-3, Nance Fall 2016 회원
USFT-NANCE-F16S2G3
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 19
전체 시간: 3,309
