주요 콘텐츠로 건너뛰기
Asus Eee PC 1201N RAM Replacement
필요한 것
  1. Asus Eee PC 1201N RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the netbook over.
    • Be sure to unplug the netbook and power off the device while working.
  2. Asus Eee PC 1201N RAM Replacement: 2 단계, 이미지 1/1
    • Push open both tabs on either side of the battery.
    • The tab on the left will click open and stay in place until you close it.
  3. Asus Eee PC 1201N RAM Replacement: 3 단계, 이미지 1/1
    • Pull the tab on the right open, while you remove battery with your other hand.
    • Pull the battery straight out ensuring that you don't damage any connectors.
  4. Asus Eee PC 1201N RAM Replacement, RAM: 4 단계, 이미지 1/2 Asus Eee PC 1201N RAM Replacement, RAM: 4 단계, 이미지 2/2
    • Remove the two 4.6mm screws using the J0 Phillips head screwdriver.
    • Then use the plastic opening tool to open the RAM door.
  5. Asus Eee PC 1201N RAM Replacement: 5 단계, 이미지 1/1
    • Push the tabs on the side of the RAM to release.
    • Only push the tabs over slightly to ensure you do not break them.
  6. Asus Eee PC 1201N RAM Replacement: 6 단계, 이미지 1/1
    • Remove the RAM by pulling it towards you.
결론
Trae Mikesell
회원 가입일: 10/04/16
394 평판
안내서 3개 작성하였습니다
USF Tampa, Team 2-3, Nance Fall 2016 USF Tampa, Team 2-3, Nance Fall 2016 회원
USFT-NANCE-F16S2G3
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 960
