주요 콘텐츠로 건너뛰기
Asus Eee PC 900 Keyboard Replacement
필요한 것
  1. Asus Eee PC 900 Keyboard Replacement, Battery: 1 단계, 이미지 1/3 Asus Eee PC 900 Keyboard Replacement, Battery: 1 단계, 이미지 2/3 Asus Eee PC 900 Keyboard Replacement, Battery: 1 단계, 이미지 3/3
    • Slide the battery's locking tabs from the locked position to unlocked positions.
    • The right tab is unlocked when a red dot is showing.
    • The left tab will have to be held in the unlocked position in order to release the battery.
  2. Asus Eee PC 900 Keyboard Replacement: 2 단계, 이미지 1/1
    • Slide the battery out while holding the left locking tab in the unlocked position.
  3. Asus Eee PC 900 Keyboard Replacement, Keyboard: 3 단계, 이미지 1/2 Asus Eee PC 900 Keyboard Replacement, Keyboard: 3 단계, 이미지 2/2
    • Caution Follow this step to detach the upper portion of the keyboard, but do not remove it from the laptop. Damage to the keyboard's ribbon cable may result if improperly executed.
    • Identify the three metal tabs holding down the laptop's keyboard.
    • Using a spudger, depress each metal tab to remove the keyboard.
    • The upper part of the keyboard should "pop up" from its holder.
  4. Asus Eee PC 900 Keyboard Replacement: 4 단계, 이미지 1/2 Asus Eee PC 900 Keyboard Replacement: 4 단계, 이미지 2/2
    • Clips hold the bottom portion of the keyboard to the laptop. Gently lift the upper portion of the keyboard and then move the entire keyboard towards the computer's screen until the ribbon cable is visible.
  5. Asus Eee PC 900 Keyboard Replacement: 5 단계, 이미지 1/1
    • Using a spudger, gently push the two black pins holding the ribbon cable towards the computer's screen.
    • Slide the keyboard's ribbon cable from the connector.
  6. Asus Eee PC 900 Keyboard Replacement: 6 단계, 이미지 1/1
    • Remove the keyboard by lifting upwards.
결론
다른 12명이 해당 안내서를 완성하였습니다.
Sheldon Chu
회원 가입일: 01/24/12
1,099 평판
안내서 3개 작성하였습니다
Cal Poly, Team 3-27, Amido Winter 2012 Cal Poly, Team 3-27, Amido Winter 2012 회원
CPSU-AMIDO-W12S3G27
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 18
전체 시간: 9,908
