주요 콘텐츠로 건너뛰기
Asus Eee PC 900 SSD Replacement
필요한 것
  1. Asus Eee PC 900 SSD Replacement, Battery: 1 단계, 이미지 3개 중 1개 Asus Eee PC 900 SSD Replacement, Battery: 1 단계, 이미지 3개 중 2개 Asus Eee PC 900 SSD Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Slide the battery's locking tabs from the locked position to unlocked positions.
    • The right tab is unlocked when a red dot is showing.
    • The left tab will have to be held in the unlocked position in order to release the battery.
  2. Asus Eee PC 900 SSD Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the battery out while holding the left locking tab in the unlocked position.
  3. Asus Eee PC 900 SSD Replacement, SSD: 3 단계, 이미지 3개 중 1개 Asus Eee PC 900 SSD Replacement, SSD: 3 단계, 이미지 3개 중 2개 Asus Eee PC 900 SSD Replacement, SSD: 3 단계, 이미지 3개 중 3개
    • Remove the small sticker on the right side of the SSD/RAM compartment cover.
    • Remove the two 4.76 mm Phillips #0 screws securing the SSD/RAM compartment cover.
  4. Asus Eee PC 900 SSD Replacement: 4 단계, 이미지 2개 중 1개 Asus Eee PC 900 SSD Replacement: 4 단계, 이미지 2개 중 2개
    • Using a plastic opening tool, lift up the bottom of the SSD/RAM compartment cover.
    • Lift the cover away from the laptop.
  5. Asus Eee PC 900 SSD Replacement: 5 단계, 이미지 3개 중 1개 Asus Eee PC 900 SSD Replacement: 5 단계, 이미지 3개 중 2개 Asus Eee PC 900 SSD Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the two 4.76 mm Phillips #0 screws that secure the SSD.
    • When the screws are removed, one end of the SSD should pop up.
    • Slide the SSD out of its socket and lift it out of the compartment.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Brian Carreon
회원 가입일: 01/25/12
300 평판
안내서 2개를 작성함
Cal Poly, Team 3-27, Amido Winter 2012 Cal Poly, Team 3-27, Amido Winter 2012 회원
CPSU-AMIDO-W12S3G27
4 회원들
안내서 16개를 작성함
5가이드 댓글
What for specifications do the SSD has? I want to replace, too but do not know the execactly specs. I bought a 30GB m-sata ssd and this is not accepted by bios and does not work.
Marcus - 답글
Refering from this site: http://www.minipciessd.com/
It seems you'll need a miniPCIe SSD and not a m-sata (even if the form factor seems the same) and that's why your bios doesn't recognize it.
adrien - 답글
There are now miniPCIe mSATA adapters. I plan to try this.
ejolson - 답글
Same problem here. I ended up putting my “new!” 64GB SSD in an adaptor and used it for a few years until it wore out!
Evidently the chips aren’t much good as withstood less than 700GB of writes according to the onboard diagnostics.
Strangely enough the adaptor worked with the original 16GB SSD and the 64.
Andre De Guerin - 답글
what kind of adapter you use? My ssd died….
rui fontes -
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 101
전체 시간: 45,797
