주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
  1. Slide the battery's locking tabs from the locked position to unlocked positions. The right tab is unlocked when a red dot is showing. The left tab will have to be held in the unlocked position in order to release the battery.
    • Slide the battery's locking tabs from the locked position to unlocked positions.
    • The right tab is unlocked when a red dot is showing.
    • The left tab will have to be held in the unlocked position in order to release the battery.
  2. Slide the battery out while holding the left locking tab in the unlocked position.
    • Slide the battery out while holding the left locking tab in the unlocked position.
  3. Caution Follow this step to detach the upper portion of the keyboard, but do not remove it from the laptop. Damage to the keyboard's ribbon cable may result if improperly executed. Identify the three metal tabs holding down the laptop's keyboard.
    • Caution Follow this step to detach the upper portion of the keyboard, but do not remove it from the laptop. Damage to the keyboard's ribbon cable may result if improperly executed.
    • Identify the three metal tabs holding down the laptop's keyboard.
    • Using a spudger, depress each metal tab to remove the keyboard.
    • The upper part of the keyboard should "pop up" from its holder.
  4. Clips hold the bottom portion of the keyboard to the laptop. Gently lift the upper portion of the keyboard and then move the entire keyboard towards the computer's screen until the ribbon cable is visible. Clips hold the bottom portion of the keyboard to the laptop. Gently lift the upper portion of the keyboard and then move the entire keyboard towards the computer's screen until the ribbon cable is visible.
    • Clips hold the bottom portion of the keyboard to the laptop. Gently lift the upper portion of the keyboard and then move the entire keyboard towards the computer's screen until the ribbon cable is visible.
  5. Using a spudger, gently push the two black pins holding the ribbon cable towards the computer's screen.
    • Using a spudger, gently push the two black pins holding the ribbon cable towards the computer's screen.
    • Slide the keyboard's ribbon cable from the connector.
  6. Remove the keyboard by lifting upwards.
    • Remove the keyboard by lifting upwards.
  7. Remove the nine 4.76mm Phillips #0 screws on the top cover of the laptop. Remove the nine 4.76mm Phillips #0 screws on the top cover of the laptop.
    • Remove the nine 4.76mm Phillips #0 screws on the top cover of the laptop.
  8. Remove the six 4.76 mm Phillips #0 screws on the back of the laptop. Remove the six 4.76 mm Phillips #0 screws on the back of the laptop.
    • Remove the six 4.76 mm Phillips #0 screws on the back of the laptop.
  9. Flip the laptop back over and identify the touchpad ribbon. Unlock the tan locking pin from the black connector by pushing the pin to the right with a spudger. Unlock the tan locking pin from the black connector by pushing the pin to the right with a spudger.
    • Flip the laptop back over and identify the touchpad ribbon.
    • Unlock the tan locking pin from the black connector by pushing the pin to the right with a spudger.
  10. Slide out the touchpad's ribbon connector by pulling the blue tab to the right.
    • Slide out the touchpad's ribbon connector by pulling the blue tab to the right.
  11. Use a plastic opening tool to gently detach the top cover from the laptop's base. See the next step for removing the cover.
    • Use a plastic opening tool to gently detach the top cover from the laptop's base. See the next step for removing the cover.
  12. Caution:  To clear the audio and microphone, lift the right half and move the cover to the left (as shown in the second picture) to prevent cover damage. Remove the laptop cover. Remove the laptop cover.
    • Caution: To clear the audio and microphone, lift the right half and move the cover to the left (as shown in the second picture) to prevent cover damage.
    • Remove the laptop cover.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Sheldon Chu
회원 가입일: 2012년 01월 24일
1,033 평판
안내서 3개 작성하였습니다
Cal Poly, Team 3-27, Amido Winter 2012 Cal Poly, Team 3-27, Amido Winter 2012 회원
CPSU-AMIDO-W12S3G27
4 회원들
안내서 16개 작성하였습니다
If you have a 900HD, there are only 8 screws in step 7. The ninth "screw" -- the second from the right in the bottom row, to the right of the blue ribbon -- is under the hard drive. You have to remove the hard drive cover on the bottom, remove the hard drive, then remove the screw there.
burneson - 답글
how much the replacement of top and back cover of this laptop?
reyesdexter - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 13
전체 시간: 6,580
