주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
  1. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Slide the battery's locking tabs from the locked position to unlocked positions. The right tab is unlocked when a red dot is showing. The left tab will have to be held in the unlocked position in order to release the battery.
    • Slide the battery's locking tabs from the locked position to unlocked positions.
    • The right tab is unlocked when a red dot is showing.
    • The left tab will have to be held in the unlocked position in order to release the battery.
  2. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Slide the battery out while holding the left locking tab in the unlocked position.
    • Slide the battery out while holding the left locking tab in the unlocked position.
  3. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Caution Follow this step to detach the upper portion of the keyboard, but do not remove it from the laptop. Damage to the keyboard's ribbon cable may result if improperly executed. Identify the three metal tabs holding down the laptop's keyboard.
    • Caution Follow this step to detach the upper portion of the keyboard, but do not remove it from the laptop. Damage to the keyboard's ribbon cable may result if improperly executed.
    • Identify the three metal tabs holding down the laptop's keyboard.
    • Using a spudger, depress each metal tab to remove the keyboard.
    • The upper part of the keyboard should "pop up" from its holder.
  4. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Clips hold the bottom portion of the keyboard to the laptop. Gently lift the upper portion of the keyboard and then move the entire keyboard towards the computer's screen until the ribbon cable is visible. Clips hold the bottom portion of the keyboard to the laptop. Gently lift the upper portion of the keyboard and then move the entire keyboard towards the computer's screen until the ribbon cable is visible.
    • Clips hold the bottom portion of the keyboard to the laptop. Gently lift the upper portion of the keyboard and then move the entire keyboard towards the computer's screen until the ribbon cable is visible.
  5. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Using a spudger, gently push the two black pins holding the ribbon cable towards the computer's screen.
    • Using a spudger, gently push the two black pins holding the ribbon cable towards the computer's screen.
    • Slide the keyboard's ribbon cable from the connector.
  6. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove the keyboard by lifting upwards.
    • Remove the keyboard by lifting upwards.
  7. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove the nine 4.76mm Phillips #0 screws on the top cover of the laptop. Remove the nine 4.76mm Phillips #0 screws on the top cover of the laptop.
    • Remove the nine 4.76mm Phillips #0 screws on the top cover of the laptop.
  8. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove the six 4.76 mm Phillips #0 screws on the back of the laptop. Remove the six 4.76 mm Phillips #0 screws on the back of the laptop.
    • Remove the six 4.76 mm Phillips #0 screws on the back of the laptop.
  9. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Flip the laptop back over and identify the touchpad ribbon. Unlock the tan locking pin from the black connector by pushing the pin to the right with a spudger. Unlock the tan locking pin from the black connector by pushing the pin to the right with a spudger.
    • Flip the laptop back over and identify the touchpad ribbon.
    • Unlock the tan locking pin from the black connector by pushing the pin to the right with a spudger.
  10. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Slide out the touchpad's ribbon connector by pulling the blue tab to the right.
    • Slide out the touchpad's ribbon connector by pulling the blue tab to the right.
  11. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use a plastic opening tool to gently detach the top cover from the laptop's base. See the next step for removing the cover.
    • Use a plastic opening tool to gently detach the top cover from the laptop's base. See the next step for removing the cover.
  12. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Caution:  To clear the audio and microphone, lift the right half and move the cover to the left (as shown in the second picture) to prevent cover damage. Remove the laptop cover. Remove the laptop cover.
    • Caution: To clear the audio and microphone, lift the right half and move the cover to the left (as shown in the second picture) to prevent cover damage.
    • Remove the laptop cover.
  13. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Flip the top cover over and identify the touchpad back plate. Flip the top cover over and identify the touchpad back plate.
    • Flip the top cover over and identify the touchpad back plate.
  14. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Identify the conductive foil. Caution: Do not completely remove conductive foil. Fold back the conductive foil from the touchpad back plate using a spudger.
    • Identify the conductive foil.
    • Caution: Do not completely remove conductive foil.
    • Fold back the conductive foil from the touchpad back plate using a spudger.
  15. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove the two 4.76mm Phillips #0 screws securing the touchpad back plate. Remove the two 4.76mm Phillips #0 screws securing the touchpad back plate.
    • Remove the two 4.76mm Phillips #0 screws securing the touchpad back plate.
  16. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove the yellow tape holding the touchpad's ribbon connector with a spudger.
    • Remove the yellow tape holding the touchpad's ribbon connector with a spudger.
  17. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use a spudger to lift the front edge of the touchpad back plate. Gently grasp the edges of the back plate and pull towards you to remove. Gently grasp the edges of the back plate and pull towards you to remove.
    • Use a spudger to lift the front edge of the touchpad back plate.
    • Gently grasp the edges of the back plate and pull towards you to remove.
  18. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Lift the touchpad out of its placeholder.
    • Lift the touchpad out of its placeholder.
결승점
다른 6명이 해당 안내서를 완성하였습니다.
Sheldon Chu
회원 가입일: 2012년 01월 24일
1,033 평판
안내서 3개 작성하였습니다
Cal Poly, Team 3-27, Amido Winter 2012 Cal Poly, Team 3-27, Amido Winter 2012 회원
CPSU-AMIDO-W12S3G27
4 회원들
안내서 16개 작성하였습니다
Where is STEP 2 1/2? my keyboard dosnt just fall out nice, how do you remove the keyboard?
Support Services - 답글
Yeah I don't know how to remove keyboard. Also once I get to step 14.. What do I do? You tell me how to identify the broken piece but is it replaceable or fixable?
el jay - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 13
30일 전: 40
전체 시간: 9,259
