주요 콘텐츠로 건너뛰기
Asus Eee PC T101MT Fan Replacement
필요한 것
  1. Asus Eee PC T101MT Fan Replacement, Battery: 1 단계, 이미지 1/1
    • Before you begin, make sure your device is powered off and not connected to the power supply.
    • Turn the tablet over and position it so it matches the picture.
  2. Asus Eee PC T101MT Fan Replacement: 2 단계, 이미지 1/1
    • Locate the sliding tab on the right and slide it to the left in order to unlock the battery.
  3. Asus Eee PC T101MT Fan Replacement: 3 단계, 이미지 1/1
    • Use a plastic opening tool to lift the battery up as you slide the tab on the left to the right.
  4. Asus Eee PC T101MT Fan Replacement: 4 단계, 이미지 1/1
    • Lift the battery out of the device.
  5. Asus Eee PC T101MT Fan Replacement, Keyboard: 5 단계, 이미지 1/3 Asus Eee PC T101MT Fan Replacement, Keyboard: 5 단계, 이미지 2/3 Asus Eee PC T101MT Fan Replacement, Keyboard: 5 단계, 이미지 3/3
    • Turn the tablet over and open it up. Insert a nylon spudger into the slots above F1, F6, F10 to pry up the keyboard.
  6. Asus Eee PC T101MT Fan Replacement: 6 단계, 이미지 1/1
    • Once you have the keyboard out, use the nylon spudger to remove the connection. You can now replace the keyboard.
  7. Asus Eee PC T101MT Fan Replacement, Fan: 7 단계, 이미지 1/2 Asus Eee PC T101MT Fan Replacement, Fan: 7 단계, 이미지 2/2
    • Peel the black strip off of the back of your Asus Eee PC T101MT to expose more screws. Remove screws from the outside of the device case (ten 7mm screws and two 8mm screws).
  8. Asus Eee PC T101MT Fan Replacement: 8 단계, 이미지 1/1
    • Remove the four 3mm screws from underneath the battery.
  9. Asus Eee PC T101MT Fan Replacement: 9 단계, 이미지 1/1
    • Remove the screws from under the keyboard. (Two 7mm and five 5mm)
  10. Asus Eee PC T101MT Fan Replacement: 10 단계, 이미지 1/1
    • Use a plastic opening tool to pry the case open and remove it.
  11. Asus Eee PC T101MT Fan Replacement: 11 단계, 이미지 1/1
    • Locate the fan and remove the screws (3mm).
  12. Asus Eee PC T101MT Fan Replacement: 12 단계, 이미지 1/1
    • Use a spudger to remove the power supply.
  13. Asus Eee PC T101MT Fan Replacement: 13 단계, 이미지 1/1
    • Remove and replace the fan.
결론
Jarnell Miranda
회원 가입일: 10/17/15
657 평판
안내서 5개 작성하였습니다
Gateway, Team 1-1, Kuhn Fall 2015 Gateway, Team 1-1, Kuhn Fall 2015 회원
GCC-KUHN-F15S1G1
1 회원
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 769
