주요 콘텐츠로 건너뛰기
Asus Eee PC T101MT RAM Replacement
필요한 것
  1. Asus Eee PC T101MT RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Before you begin, make sure your device is powered off and not connected to the power supply.
    • Turn the tablet over and position it so it matches the picture.
  2. Asus Eee PC T101MT RAM Replacement: 2 단계, 이미지 1/1
    • Locate the sliding tab on the right and slide it to the left in order to unlock the battery.
  3. Asus Eee PC T101MT RAM Replacement: 3 단계, 이미지 1/1
    • Use a plastic opening tool to lift the battery up as you slide the tab on the left to the right.
  4. Asus Eee PC T101MT RAM Replacement: 4 단계, 이미지 1/1
    • Lift the battery out of the device.
  5. Asus Eee PC T101MT RAM Replacement, RAM: 5 단계, 이미지 1/1
    • Locate the compartment where the RAM is stored.
  6. Asus Eee PC T101MT RAM Replacement: 6 단계, 이미지 1/2 Asus Eee PC T101MT RAM Replacement: 6 단계, 이미지 2/2
    • Grab a drive adapter and a PH0 phillips head bit and use the screwdriver to remove the 5mm screw from the cover of the compartment.
  7. Asus Eee PC T101MT RAM Replacement: 7 단계, 이미지 1/2 Asus Eee PC T101MT RAM Replacement: 7 단계, 이미지 2/2
    • Use a plastic opening tool to remove the cover.
  8. Asus Eee PC T101MT RAM Replacement: 8 단계, 이미지 1/3 Asus Eee PC T101MT RAM Replacement: 8 단계, 이미지 2/3 Asus Eee PC T101MT RAM Replacement: 8 단계, 이미지 3/3
    • In order to release the RAM module, you will need to move the metal tabs on both sides at the same time. This can be accomplished by using plastic opening tools or your fingers.
  9. Asus Eee PC T101MT RAM Replacement: 9 단계, 이미지 1/2 Asus Eee PC T101MT RAM Replacement: 9 단계, 이미지 2/2
    • Once you move the tabs, the RAM module will pop up and you can remove it with your fingers so you can put in a replacement.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jarnell Miranda
회원 가입일: 10/17/15
657 평판
안내서 5개 작성하였습니다
Gateway, Team 1-1, Kuhn Fall 2015 Gateway, Team 1-1, Kuhn Fall 2015 회원
GCC-KUHN-F15S1G1
1 회원
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 15
전체 시간: 501
