주요 콘텐츠로 건너뛰기
Asus EeeBook X205TA Battery Replacement
필요한 것
  1. Asus EeeBook X205TA Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Asus EeeBook X205TA Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Unscrew all ten 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
  2. Asus EeeBook X205TA Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA Battery Replacement: 3 단계, 이미지 2개 중 1개 Asus EeeBook X205TA Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Unscrew all six 2mm screws using Philips #2 screws along the edges of the L-Shaped battery.
    • Any tape or cords that run along the battery should be carefully pushed to the side.
  4. Asus EeeBook X205TA Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Disconnect the battery from the motherboard by pulling the No-Fuss Ribbon cables out of the connector.
  5. Asus EeeBook X205TA Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Carefully lift the battery out of the laptop.
결론
Follow the guide in reverse order to reassemble the device.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Lorena Santiago
회원 가입일: 10/06/16
712 평판
안내서 4개를 작성함
USF Tampa, Team 2-2, Sullivan Fall 2016 USF Tampa, Team 2-2, Sullivan Fall 2016 회원
USFT-SULLIVAN-F16S2G2
3 회원들
안내서 10개를 작성함
댓글 11개
By any chance , Can we run this laptop without battery ? I mean directly from AC ? Please suggest
Sourabh Verma - 답글
No, you must have the battery on.
Tayler Grant -
is this under warenty
bla bla - 답글
If you have one….
Tayler Grant -
My battery is stuck on orange led mode. My laptop cannot identify the battery….
Tayler Grant - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 64
전체 시간: 14,499
