소개
This guide will help you replace your Asus EeeBook X205TA screen in case the screen is broken, damaged or worn out. If disposing of the screen, please follow the laws and regulations for proper disposal.
This guide only covers removing the entire LCD screen assembly.
필요한 것
Unscrew all 10 screws located on the bottom of the laptop using 2mm Phillips Screwdriver.
거의 끝나갑니다!
결론
다른 3명이 해당 안내서를 완성하였습니다.
