주요 콘텐츠로 건너뛰기
Asus EeeBook X205TA Screen Assembly Replacement
필요한 것
  1. Asus EeeBook X205TA Screen Assembly Replacement, Screen Assembly: 1 단계, 이미지 2개 중 1개 Asus EeeBook X205TA Screen Assembly Replacement, Screen Assembly: 1 단계, 이미지 2개 중 2개
    • Unscrew all 10 screws located on the bottom of the laptop using 2mm Phillips Screwdriver.
    • Keep in mind that some of the screws vary in length, so keep track of which screws were placed in each hole.
  2. Asus EeeBook X205TA Screen Assembly Replacement: 2 단계, 이미지 1개 중 1개
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA Screen Assembly Replacement: 3 단계, 이미지 3개 중 1개 Asus EeeBook X205TA Screen Assembly Replacement: 3 단계, 이미지 3개 중 2개 Asus EeeBook X205TA Screen Assembly Replacement: 3 단계, 이미지 3개 중 3개
    • Unscrew the four screws using Philips #2 screwdriver that connect the screen to the inside of the case for the laptop.
  4. Asus EeeBook X205TA Screen Assembly Replacement: 4 단계, 이미지 1개 중 1개
    • Unplug the No-Fuss Ribbon connector of the screen from the motherboard.
    • Carefully lift the screen away from the case.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Lorena Santiago
회원 가입일: 10/06/16
736 평판
안내서 4개를 작성함
USF Tampa, Team 2-2, Sullivan Fall 2016 USF Tampa, Team 2-2, Sullivan Fall 2016 회원
USFT-SULLIVAN-F16S2G2
3 회원들
안내서 10개를 작성함
1가이드 댓글
What's that small black screen hanging out from the laptop
Tayler Grant - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 24
전체 시간: 2,594
